Paroled
Illinois
I have a new 2021 GMC 2500, Diesel. It will not engage trailer brakes unless the brake pedal is mashed to the floor. It is this way on any trailer it’s hooked up to. My 04 Silverado works fine on my trailer. Dealership could not diagnose. Opened case with GMC and they have sent engineers twice and no luck. Anyone hooked up an aftermarket brake controller to a new GM This has been going on for 7 months
ktmrfs
Portland, Oregon
does the manual control activate the brakes? What is the setting on the brake controller?
On my 2015 Denali I have it set on 5 and activated brakes on both trailers, and I feel the trailer brakes when I check using the manual control slider.
2011 Keystone Outback 295RE
Paroled
Illinois
It will work with the manual slide
kellem
Shenandoah valley,VA
Wow,certainly frustrating and something I've yet to hear of.
Perhaps cheaper in the long run to install an aftermarket brake controller.
Have you invested in a brake tool to verify pad spacing. Possibly the trailer and not the truck.
riltri
Husk & Steinhatchee
Find the fuses associated with the brake...I think there are 2. Take both out at the same time and reseat them. That will force the truck to reboot the brake controls. I have heard that has worked. Good Luck!!
Blue Ridge Mtns - NC
Thermoguy
Graham, WA
If it works with the manual slide, then the brakes work and the controller. The issue seems to be the foot actuation dealing with applying the brakes on your truck. I wonder if that is controlled by a computer or by some actual physical connection. They might have to replace one of those items.
Owens River area
With a 2021 truck under warranty, demand Chevrolet fix it. Keep escalating up the chain of command.
BenK
SF BayArea
Too many potentials for these 'highly integrated trailer brake controllers', but IMHO, it sounds like the MC PSI sensor is the main culprit in your case
It might need bleeding and/or replacement
Edit...be careful, too often they just give up and replace subsystems/components/etc. trying to 'fix' it...
And, too often, the root cause is still there, but now masked by those new components/sub-systems...
Guessing this won't be just a GM thing, but all OEMs now have 'highly integrated trailer brake systems'...
edited 12/11/21 11:19am by BenK *
-Ben Picture of my rig
LITEPHIL
AZ
So GM has sent engineers out and they can't figure it out but maybe someone here can? Doesn't it have a factory brake controller?
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
ktmrfs
Portland, Oregon
Thermoguy wrote: If it works with the manual slide, then the brakes work and the controller. The issue seems to be the foot actuation dealing with applying the brakes on your truck. I wonder if that is controlled by a computer or by some actual physical connection. They might have to replace one of those items.
Since the manual slide works, that means the integrated controller knows a trailer with brakes is connected and it can power the brakes.
On my 2015, the integrated controller works so well that I don't feel the typical feedback one gets from a aftermarket controller as the trailer brakes get applied. Feedback is very subtle till you do a very hard stop. And I did have one occasion where I had to do a 60mph panic stop when a merging car decided to stop in the traffic lane! Control was amazing, ABS on the truck was full on and the trailer stayed straight as an arrow.
As you stop if your in tow haul mode does the dash indicator for the trailer brakes show the trailer brake force and does it vary as you change braking force? If so I suspect it is working.
