RV.Net Open Roads Forum: Tech Issues: Tank treatment that can restore sensor accuracy?
 > Tank treatment that can restore sensor accuracy?
Posted: 12/18/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
The standard "Sensor" is basically a nail. if it's wet the level must be that high right (NO it's not)
Sometimes, you add like a half to cup of Dawn. plus a half to cup of Calgon water softerner and fill tank to aroudn 1/3 or 1/2 with water and drive and dump. once the bubbles pop it will show empty.. SOMETIMES Steam cleaning works. Sometimes a water jet (Valterra Master blaster though I don not like the design of the break it off jet) can blast the slime off the wall. Sometimes.
See Level Sensors.. those work
3 tons
NV.
Posted: 12/18/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons wrote:
IAMICHABOD wrote:
3 tons wrote:
Dump a large bag of ice cubes into the tank and drive stop and go for a few miles…
3 tons
And the Myth Continues [emoticon]
Ha, unless you’re inside the tank, how would you know?? (lol!)
3 tons
Well, not too sure about the ‘mythology’ so please excuse my poor attempt at humor [emoticon] but on a more serious note you could do what I did (almost 13 years ago) and invest in a SeeLevel monitor by Garnet…The sensors rest OUTSIDE of the tank (via double stick tape) and very accurate and trouble free - This puts this dreaded issue behind you…
3 tons
Dave H M
IL
Posted: 12/18/21 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
If it is the black tank the wand from wally world will do the trick.
pianotuna
Regina, SK, Canada
Posted: 12/18/21 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD welcome to playing "whack a mole". You are in excellent company.
Teleman
To have the sensors work they have to be treated OFTEN. But we can't make a reliable level sensor even for nuclear reactors.
Regards, Don
jjrbus
FT Myers FL
Posted: 12/18/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I use Seelevel. Fresh water tank is where I can see the level. Turn off water push pedal, shine light in hole and see level. Grey tank best guess.
time2roll
Posted: 12/18/21 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a Quickie Flush with custom spray pattern directed at the sensors and extra water to the rear of the tank.
OEM sensors work like new for 16 years.
675w Solar pictures back up
morphrider
Colorado
Posted: 12/18/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have never had a reason to use the ice theory in any of my other trailers. The reasoning behind the time I did use it was due to waste build up that had solidified from the previous owner before it sat on a dealers lot. It was a 3 hour drive home to the storage lot, and it worked for me anyway.
phillyg
SWFL
Posted: 12/19/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Nothing works. Let me say again, NOTHING WORKS! That's my story and I'm sticking to it.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Posted: 12/19/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
NOPE. won't.
doughere
Mooresville NC
Posted: 12/29/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
NO
