RV.Net Open Roads Forum: Truck Campers: Lance 2001 920 truck camper
 > Lance 2001 920 truck camper
RonandSharon
New Hampshire
Posted: 12/19/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know the routing of the 110vac wire for the outlet over the couch I know it goes behind the Refer, but where from there?
Joe417
AL
Posted: 12/20/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
If it goes behind the fridge, it may run from the receptacle in the outside fridge compartment. I'm just guessing. The TCs I've had only had 3 circuits. A left and right 110V receptacle circuit and the air conditioner.
You can pick up a wall scanner that has stud, metal, and AC scan to trace the path.
On our TC, both circuits have a GFI. One of those could be tripped.
Joe & Evelyn
RonandSharon
New Hampshire
Posted: 12/20/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your input, I have 4 outlets three on drivers side one on passenger side all on the same circuit passenger side has no power so I will have to trace it.
Kayteg1
California > Nevada
Posted: 12/20/21 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I parted out 2001 Lance 1161 and they used unique power outlets with press-in tabs. Assuming you have the same outlets, I would check them in the line as that IMHO is weak point.
RonandSharon
New Hampshire
Posted: 12/20/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply, I have removed the **** outlet, but the problem is no ac in the wire.
Joe417
AL
Posted: 12/20/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Ron
I think Kayteg1 is talking about looking at the other outlets to see if you find a loose wire that exits a receptacle going (possibly) to the one that doesn't work. Many TC use insulation displacement receptacles where the wire is pressed into the outlet. Very similar to a Scotch lock connector. These aren't necessarily great connections. Also, make sure you check the one the fridge is plugged into.
Kayteg1
California > Nevada
Posted: 12/20/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
What Joe says. Even my 1161 had several AC outlets, it had only 2 breakers and the line was going from outlet #1 to #2 to #3 and farther.
Meaning no power in outlet 3 might be result of poor connection in outlet #2
RonandSharon
New Hampshire
Posted: 12/21/21 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Joe and Kayteg thanks, I will check them today, weather permitting.
AnEv942
CA
Posted: 12/21/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Generic 01 lance diagram
Likely not too helpful, doesnt show wire routing but shows daisy chain wiring mentioned, Physical routing on ours, not a lance, but cross over left to right in water tank box. On ours there's an AC junction box inside water tank box and also in one of the seat boxes, just pointing out there may be connections at other than receptacles.
Our camper projects page
Kayteg1
California > Nevada
Posted: 12/21/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
From my memory Lance 1161 had GFCI over kitchen countertop and the extension went to bathroom and outside plug.
Interior plugs had 2nd breaker with no GFCI, than fridge and micro had additional breakers.
What really surprised me, when taking camper apart was finding battery combiner, or isolator in the system.
My Ford had charging circuit ignition-activated, but I read how lot of Chevy, or Dodge owners worry about discharging truck battery by camper.
Worth looking into hidden compartment, or read the manual if you have it to find if you might have a protection you are not aware about.
* This post was edited 12/21/21 10:10am by Kayteg1 *
