RV.Net Open Roads Forum: Fifth-Wheels: TV Upgrade, Hitch question: What would you do?
 > TV Upgrade, Hitch question: What would you do?
humblerb
houston
Posted: 12/20/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Currently have a 2018 RAM 2500 Short Bed.
Hitch is a BW Patriot Slider.
Currently mounted on rails.
I am upgrading to a 2021 RAM 3500 with Puck System in bed.
Contacted BW about a puck adapter.
Unfortunately, they do not have one for the Patriot.
Only for the Companion.
The BW Rep did say "they" make a frame type adapter that will fit the Patriot, but it sets up high enough that the hitch won't slide.
When I asked who "they" are, he replied Demco and maybe Reese.
The 3500 is a long bed, so I really shouldn't need to slide the hitch any longer. I certainly would prefer to use the pucks rather than have rails installed.
Any negative thoughts on installing the Demco adapter?
I'm in no hurry. No trips planned until Spring.
ford truck guy
Pennsylvania
Posted: 12/20/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
If it were ME, I'd sell everything and put the money towards. brand spankin new B&W Companion OEM Puck...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
humblerb
houston
Posted: 12/20/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Since I have some time, I think this is what I am leaning toward.
Since the Puck Frame is not specific to the Patriot, think I'd feel better with one that was made for the hitch and the truck.
Thanks,
CoMoCo
Welland, ON, Canada
Posted: 12/21/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
New truck = new hitch! Get what works with the puck system instead of "modifying" the old hitch.
'15 GMC Denali 3500 DRW D/A; '13 Lifestyle 36FW
laknox
Arizona
Posted: 12/21/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
What ^^^he^^^ said! My brother was in the same boat and was able to recover about 1/3 the cost of the new hitch from selling his old Companion.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Cummins12V98
on the road
Posted: 12/21/21 08:52am Link  |  Quote  |  Print  |  Notify Moderator
As I mentioned on the other thread sell what you have on CL. You will have no problem selling it for a good price. Now buy the proper hitch for your Nice new trucks puck system.
If you want a top quality tool box the HighwayProducts pictured can't be beat.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 12/21/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
When installing that nice new hitch be sure to place the side supports closest to the cab with the straight edge towards cab also. This will place the center of the kingpin forward of center of rear axle allowing some weight to transfer to the front axle.
Good call going to a LongBed truck!!!
Njmurvin
Simi Valley
Posted: 12/22/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Agree on getting a new hitch that fits your pucks. I looked at using an "adapter" with my old Superglide and the Pullrite salesman talked me out of it. He said it would be safe, but would add "slop" into the connection and raise the hitch at least another inch. These newer trucks are already too high to begin with (but that's a topic for another thread).
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
cummins2014
Utah
Posted: 12/22/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Baloney , no slop in the adapter , yes you would have slop in the hitch the same if you had slop connected to standard bed rails . If that’s the case than any hitch connected to the pucks would have slop .
austinjenna
Columbus, Ohio
Posted: 01/03/22 05:34am Link  |  Quote  |  Print  |  Notify Moderator
If it were me, I would get an air ride hitch
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
