RV.Net Open Roads Forum: Class C Motorhomes: Differential Service
 > Differential Service
EMD360
Arvada, CO
Posted: 12/20/21 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone had to have their differential serviced? Never an issue on our first RV. This one is in the shop for rear brakes and they found the oil low and metal shavings in it. I read up on differential requirements and the oil should be checked between 50000 and 60000 miles. That’s where we are on mileage. I had noticed a new roaring noise on acceleration which might be traced to this problem. Shop will service. Hopefully just new seals and oil.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
Posted: 12/20/21 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
Should it be? Absolutely. 50k on an axle largely operated at max capacity, it’s due.
However realize “servicing” is nothing more than dumping the oil and replacing. So it shouldn’t be very expensive if it’s already on the rack.
$100 in fluid and an hour of shop time. Any more is overcharging.
Also be ware that metal shavings isn’t necessarily bad. Metal chunks are. All axles lose some material through operation, that’s why the magnet is there, to collect it.
Can’t help diagnose the noise but it’s possible it’s the rear end.
2017 Heartland Torque T29
PartyOf Five
Wheaton, IL
Posted: 12/21/21 04:50am Link  |  Quote  |  Print  |  Notify Moderator
I ran into the same question when doing other fluids at 60 and every interval after. Shop said they could but new fluid could actually cause more harm by being pristine, then leading to other issues, particularly before heading out of a trip. Thanks for raising the topic for more perspectives.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
Dusty R
Charlotte Michigan 48813
Posted: 12/21/21 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Why/How would new fluid cause problems ?
PartyOf Five
Wheaton, IL
Posted: 12/21/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
He said when the particulate matter in existing fluid will, when replaced, make the seals/ gaskets the "weakest link" & they may fail more readily. Let a sleeping dog lay.
enblethen
Moses Lake, WA
Posted: 12/21/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Whoever is doing your oil changes should be checking the differential for fluid level. At 60,000 miles on MH, I would say fluid change is over do. Axle seals would be normally replaced when doing rear brakes. Did you or shop see any locations where fluid is leaking out? Are you sure you are not being scammed?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Desert Captain
Payson
Posted: 12/21/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
When I bought our 24' E350 Class C it had 6,205 miles on it. The first thing I did was to replace the oil, trans fluid and differential fluids with full synthetic Since then I have changed the differential and trans every 30,000 miles. No metal bits or shavings yet and everything works well... no drips, no runs, no errors.
[emoticon]
theoldwizard1
SE MI
Posted: 12/21/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Do you trust the shop doing the service ?
A small amount of metal is acceptable, but a large amount means trouble !
EMD360
Arvada, CO
Posted: 12/21/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I know this shop is expensive but they are a 24 hour truck shop, very popular with big RV’s and commercial trucks and do good work. I’ve used them before but know they are very high on service charges. I’m willing to pay high if I get really good service. I had the oil changed and fluids checked when I bought it in March at a grease monkey. They replaced the air filter but said nothing about the diff. The noise was new since our last trip in September. I didn’t ask them to check it out because I was not sure it was a problem. Still getting to know this rig. I read about differential noise and what I experienced seemed to fit. When I get it back I’ll know if the noise was corrected. If it was I don’t care that it cost $1300. I’ll check to see what they actually did. If they replaced the oil and all seals the internet says that’s the going rate. If they just changed the oil should be less. But I think they will have it apart to check the gears for wear. I think by using them I will be able to keep this RV in good shape. That’s worth a lot. I have a warranty plan but I bet this is not covered. Considered a maintenance issue. I’m going to check.
EMD360
Arvada, CO
Posted: 12/21/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
My hunch was right. Actually very few repairs are covered by this warranty through Good Sam. Im not going to renew. Had it for insurance in case something was major wrong with the used RV but the stuff that’s covered is most unlikely to break. Lots of the wiring is covered and the manifolds for instance. Several sensors. But the deductible is $500. The catalytic converter but not for theft just malfunction.
Edit;
Oops I’m wrong. Diff is covered I think. I was looking at the coverage addendum. I registered the claim but they have to talk to the shop.
* This post was last edited 12/21/21 12:21pm by EMD360 *   View edit history
