RV.Net Open Roads Forum: General RVing Issues: water filter for taste and smell
 > water filter for taste and smell
TechWriter
Part-Timing Again
Posted: 12/25/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Does anyone know of a system that can get rid of both taste and smell while allowing enough water flow for a shower?
I put a lot of filtration on my old Class A, and to ensure adequate water pressure I just made sure to turn on my water pump and shower on my water tank supply.
Don't you have the same option?
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 gasser)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 gasser)
www.rvSeniorMoments.com
DISH TV for RVs
Cummins12V98
on the road
Posted: 12/25/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
FWC wrote:
You may want to check that Pentek filter - pretty sure they are made in China [emoticon].
Simplest option is one of the inline hose thread activated carbon water filters for city water and tank filling. That won't help if the issue is your hot water heater though.
Last ones bought were Made In USA, would not surprise me if they changed to China as it's hard for them to compete.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
pianotuna
Regina, SK, Canada
Posted: 12/25/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Second Chance wrote:
A filter that will eliminate tastes and smell and permit enough flow for a shower doesn't exist in a size suitable for RVs. We installed one of these under the sink for drinking and cooking. It works really well. It's the ceramic shell and carbon block (not granules) that makes the difference:
Under-sink filter
Rob
I found a charcoal with a flow rate of 4 gallons per minute. I think showers come in at about 2 to 3 gallons per minute.
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 12/25/21 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
What sort of taste and odor are we talking about? Must be kinda bad if a shower is a problem.
I have not been there yet--but apparently the water stinks badly.
It may be that they are not using a hose intended for potable water.
I'll know more after January 7th.
Second Chance
Wherever...
Posted: 12/25/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Under-sink filter
Rob
Granulated charcoal and carbon block aren't the same.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
pianotuna
Regina, SK, Canada
Posted: 12/25/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if using the tank is an option. It is a fifth wheel that will not be moved anytime soon. It does solve any flow rate problems.
This is not an area where I'm knowledgeable.
TechWriter
Part-Timing Again
Posted: 12/26/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I believe your 5th wheel will have a gray, a black, and a water tank.
pianotuna
Regina, SK, Canada
Posted: 12/27/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Techwriter, It also has a Galley tank.
For myself, the fresh water tank would be an easy fix with an RO slowly filling it. But the end user is not me.
It needs to be a set up that is user friendly and not require a lot of intervention.
The users have already managed to overflow the galley tank--as they did not know where the drain valve was located.
