RV.Net Open Roads Forum: Travel Trailers: Tandem axle vs single
 > Tandem axle vs single
Bobbo
Wherever I park
Posted: 12/26/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
Lwiddis wrote:
Snip... Blowing a tire, which will happen…and to you, is another. Snip...
Not necessarily! I have been driving for 70 years, 50 of them towing a trailer of some kind, and have never had a blowout in all of those years. Only had one flat tire and had that changed in about 30 minutes.
Barney
What Lwiddis said. I haven't had a blowout, but I was at a campground waiting for a friend to arrive. I got a call, he was about 10 miles out and had lost the tread off of a trailer tire, shredding the tire. He had called AAA. I drove over there and put his spare on for him. If it was a single axle trailer, it would have been on the rim, or on its side.
Bobbo and Lin
mobeewan
Hampton, Va
Posted: 12/26/21 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Tandem axle has less bounce, less sway.
Gdetrailer
PA
Posted: 12/26/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Bobbo wrote:
Barney
Sure, single axle would end up with the rim hitting the ground.
BUT, the exact same thing WILL happen with dual axles.
Flatten a tire on a dual axle by taking the valve core out and you will see that rim drop the entire distance of the sidewall. Put a load on the trailer like the average RV'r does and that rim WILL be touching the ground. Dual axle suspension will attempt to equalize and will push the blown/missing tire of that axle down until the good tire hits the top of the suspension limit.
Remove the flat tire on dual axle and the drum will start hitting the pavement. It is for that reason one must "strap" and restrain the axle backup to "normal position" if one were to attempt to drive on with a missing tire.
As far as "tipping over" goes, you have bigger problems if your single axle trailer tips over with a 5" drop. Tire sidewall at most is 6" tall with air, no air that shrinks to about 5" (tread portion of tire thickness is nearly 1" including the rubber under the tread).
A single axle trailer with a flat is not going to tip over unless you do something dumb to help it over the center of gravity.
rexlion
Broken Arrow OK
Posted: 12/26/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I greatly prefer single axle trailers. My rear tandem tires would pick up so many nails and screws, it was ridiculous. Plus double the cost for tire replacement.
I have had blowouts with both types. No big deal either way. No, the trailers were never in danger of tipping.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Posted: 12/26/21 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Merry Xmas Barney!
Thx for the delete….
2017 Heartland Torque T29
JIMNLIN
Oklahoma
Posted: 12/26/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I've never pulled a single axle rv trailer but several single axle company cargo trailer used as on site tool trailers.
We finally convinced the company to do away with the all single axle trailers and go with tandem axles on anything over 14' long.
The benefits of a tandem axle trailer far out weighs a single axle trailer...JMO after pulling them for a living.
pbeverly
South Carolina
Posted: 12/27/21 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Barney
I had 2 blowouts last June. One on my way to site and another on the way home. 1st one did $4500 worth of damage. Took it to RV shop 7/5/2021. All the parts needed just arrived about 2 weeks ago.
Ridgeway, SC
Huntindog
Phoenix AZ
Posted: 12/27/21 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Barney
My last of several blowouts was in 2006.I then made the jump to LT tires and never looked back.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
eend
Alberta
Posted: 12/27/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Single axle usually has bigger size tires.
Also if you need to replace tires, single axle is cheaper than tandem.
2019 VW Tiguan
2015 F150 ecoboost
2013 Arctic Fox 22G
1971 Boler 1300
nickthehunter
Southgate, MI
Posted: 12/27/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If my dual axle trailer has a blowout I will proceeding cautiously, at minimal speed, up the next exit and to the nearest safe spot. I won’t be changing it on the side of the road while cars and trucks fly past at 70 mph. Which is the same thing that would happen if I had a single axle trailer, my truck, or any other vehicle.
