RV.Net Open Roads Forum: Travel Trailers: I Winterized ............. but then this happened.
 > I Winterized ............. but then this happened.
Texas Nomad
Posted: 12/28/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I winterized my used but newly purchased Coachmen Freedom Express 192RBS about two weeks ago. Today, I went to the storage facility to perform a minor repair. I looked into the commode bowl and discovered that all of the anti-freeze (about a quart) I poured in during winterization was gone. It was bone dry! I realize that the seal is leaking. This never happened in my prior Coachmen TT. Is there a DIY fix for this? Am I looking at a trip to the RV repair shop? Thanks
ReneeG
Meridian, Idaho
Posted: 12/28/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes it's as simple as it getting out of alignment around the inner ring. Put on gloves and feel for it to be seated/sealed evenly. Sometimes too, the ring rubber can dry out. We've put plumbers putty on ours and it works.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
bgum
South Louisiana
Posted: 12/28/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Model and make of toilet?
kellem
Shenandoah valley,VA
You can order the seal and install yourself but may have to do some fancy camera work behind the toilet to get serial #, what I had to do.
Once a seal goes dry, they expire.
lenr
Indianapolis, IN
Posted: 12/28/21 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Put on plastic gloves and wipe Vasoline all over the seal. This is approved and recommended by Dometic. Dometic is also an easy seal change.
spoon059
Just north of D.C.
Posted: 12/28/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thetford makes a RV Toilet Seal and Lubricant for about $8. Not sure if it can revive an older seal or not. Not to be funny, but another option might be some high mileage oil. It has an additive that slightly swells rubber seals. I'd research that before trying it though.
My old camper had that problem, but it wasn't worth fixing for me. We camped year round and I would simply add a bunch of water (or antifreeze) to the bowl that it wouldn't complete leak out before the next trip.
2015 Ram CTD
2015 Jayco 29QBS
msmith1.wa
Tacoma, WA
Posted: 12/28/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
You don't have to worry about it freezing if ther isn't any water in it.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
bob213
Fresno, CA
Posted: 12/28/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
If that is an approved solution by Dometic it must be new. I have always been told to not use any petroleum product on the seal. Plumbers silicone was the correct answer from everything I've ever been told. Please post where Dometic states this as I can't find it.
Bobbo
Wherever I park
Posted: 12/28/21 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
True, but a seal can dry out and crack. It should be kept wet.
Bobbo and Lin
time2roll
Posted: 12/28/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Used RV? I would install a new seal.
675w Solar pictures back up
