RV.Net Open Roads Forum: Fifth-Wheels: Reese Sidewinder
 > Reese Sidewinder
mxdad777
Ca
Posted: 12/28/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Duramax standard bed truck that I pull a Grand Design Reflection 337 RLS with. I have a non sliding B&W hitch and have never had any issues with clearance. It gets close occasionally if I have to make a really tight turn, but no problems.
I recently bought a rack that goes over the front of my hood to haul my 14’ boat on. This rack has a support that mounts to the bed behind the cab and so I’ve lost 2 1/2” of clearance. Under normal towing conditions I won’t have a problem, but I’m not as confident in tight turns. I really don’t want to go with a slider (too heavy) and so I was thinking of going with a Reese Sidewinder. Does anyone have any experience with the Sidewinder, good or bad? I’d appreciate any feedback. Thanks
* This post was edited 12/28/21 10:53pm by mxdad777 *
2021 Grand Design Reflection 337 RLS
2019 GMC Duramax 4x4
ACZL
UPstate,NY
Posted: 12/29/21 01:07am Link  |  Quote  |  Print  |  Notify Moderator
Have you turned the B&W around? In doing so you'll gain some add'l room
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
MFL
Midwest
Posted: 12/29/21 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Your B&W hitch is adjustable ahead/back, by relocating the arm position, or as said above, turning around. If you are already in the full rearward arm position, the Sidewinder will help.
Which B&W do you have? A Patriot on rails will work. If the Companion for GM oem pucks, the sidewinder will work. If you have the single point attachment Companion 3500, it is not recommended to use the Sidewinder.
Jerry
* This post was edited 12/29/21 06:08am by MFL *
mxdad777
Ca
Posted: 12/29/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I already have the B&W in the most rearward position. And yes my hitch is the factory GM 4 point attachment. This is why I’m thinking the Sidewinder will be my best option.
MFL
Midwest
Posted: 12/29/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Should be GTG with Sidewinder.
I've no personal experience with a SW, but a neighbor of mine changed to one, with a standard bed Ford. He had a tight maneuver backing in his driveway. He liked the advantage the SW gave, even giving a quicker reaction time, as well as clearance.
Jerry
C Schomer
Pueblo West, Co.
Posted: 01/07/22 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a used fiver with a sidewinder but I have a standard 8 foot bed so the sidewinder is in my scrap pile. Otherwise they work fine but you need a fifth wheel hitch that’s approved to use a sidewinder pin box.
Beaker
Brevard, NC
Posted: 01/08/22 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Sidewinder. Like it, easier to back up.
Make sure that the "universal adapter" fits your hitch.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
 > Reese Sidewinder
