RV.Net Open Roads Forum: Truck Campers: Trailer connect
 > Trailer connect
GregA
Montana
Posted: 12/29/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
I have a question regarding "Trailer Connect" on my Ford F350.
I have both a 5th wheel and slide-in camper. The 5th wheel seems to just "connect" if the truck is running. The Slide-in camper only "connects" once I press the brake on the truck.
Anyone know why? I'd like for the slide-in to "connect" without depressing the brake. I have my reason I can get into later but in short I want the batteries in the camper to start charging from a remote truck start. Which I think it does with the 5er.
Cheers,
Greg
ScottG
Bothell Wa.
Posted: 12/29/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Computer constantly sends tiny signal down brake wire to sense trailers brake magnets presence. So it knows automatically.
kohldad
Goose Creek, SC
Posted: 12/29/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Since the truck is sensing the resistance in the trailer brakes, you could add a resistor to the trailer brake pin. I've never done it but did a quick search and found this thread which did describe a solution down on 1/20/2015. https://www.f150forum.com/f38/can-i-fool........-i-have-electronic-brakes-286312/index2/
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Buzzcut1
Norcal
Posted: 12/29/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Wire it like Lance does. Skip the trucks harness wiring system. Run an 8 gauge wire from the battery through a 50amp relay to the power pin of a dedicated camper bed plug. Truck on camper charges.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Posted: 12/30/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I’m waiting for the “reason”….lol.
(Only because there’s no practical benefit to battery charging during a short duration of a remote start)
StirCrazy
Kamloops, BC, Canada
Posted: 12/31/21 06:03am Link  |  Quote  |  Print  |  Notify Moderator
I have a 14F350 and my camper doesnt show up at all. I believe it used the brake circut to sence if there is something on it but I am not positive on that. it makes sence though as my camper is the only thing that doesnt show up.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Posted: 12/31/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Steve
But the lights and power still work, correct?
OP must be insinuating that that stuff doesn’t work until brake depressed. Which seems odd, although I don’t know how the newer Fords work.
Bedlam
PNW
Posted: 12/31/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
My camper and brakeless trailer are not seen by the Ford or Ram. I believe it must have the brake circuit active and have not seen a difference when the brake pedal is applied. My Ford power wire was ignition enabled while my Ram is always present.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
Posted: 01/03/22 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
@GregA….
Is now a good time?
StirCrazy
Posted: 01/03/22 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Steve
yup they do. well not power, I have it disabled for the camper and the 5th wheel.
Steve
 > Trailer connect
