RV.Net Open Roads Forum: Class C Motorhomes: Ready brake
 > Ready brake
wd
SoCal
Posted: 01/01/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone set up a ready brake break away on a 2005 TJ Wrangler? Looking for the best location to mount the red box.
Thanks for any help.
ae5573t
Alabama
Posted: 01/02/22 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2006 TJ. Its been a number of years, but as I recall my TJ had an extra battery tray near the steering column. I didn't have an extra battery so my extra battery tray was empty. There was a bolt in the rear of the tray that wasn't too far from the firewall where I had run the ready brake cable to the break pedal arm. I used an L bracket bolted to this bolt on the extra battery tray. I bent the L bracket slightly and bolted the emergency break away box to the L bracket and was able to run the break away cable through the firewall to the brake pedal arm. Hope this helps.
2018 Thor Tuscany 42GX
2015 Jeep Wrangler JK Unlimited
 > Ready brake
