RV.Net Open Roads Forum: Class C Motorhomes: Ready brake
 > Ready brake
wd
SoCal
Posted: 01/01/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone set up a ready brake break away on a 2005 TJ Wrangler? Looking for the best location to mount the red box.
Thanks for any help.
ae5573t
Alabama
Posted: 01/02/22 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2006 TJ. Its been a number of years, but as I recall my TJ had an extra battery tray near the steering column. I didn't have an extra battery so my extra battery tray was empty. There was a bolt in the rear of the tray that wasn't too far from the firewall where I had run the ready brake cable to the break pedal arm. I used an L bracket bolted to this bolt on the extra battery tray. I bent the L bracket slightly and bolted the emergency break away box to the L bracket and was able to run the break away cable through the firewall to the brake pedal arm. Hope this helps.
2018 Thor Tuscany 42GX
2015 Jeep Wrangler JK Unlimited
travisc
Pacific NW
Posted: 01/23/22 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
If you don’t have abs on the rig, there is a tray on 5he drivers fender liner, did our braking system there on our 06
Winnebago Access 24V
wd
SoCal
Posted: 01/24/22 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I finally made an L bracket and bolted it to the front lower part of the Jeep. Thanks for the replies.
 > Ready brake
