RV.Net Open Roads Forum: Towing: 2007 6.7 ram fuel change
Search only in Towing
Open Roads Forum  >  Towing
 > 2007 6.7 ram fuel change
Espee
Santa Claritap, Ca
Posted: 01/01/22 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Been using B5 diesel the life of this truck and last time I went to fuel it up in town my favorite station changed to B20 fuel. I drove all over but everyone is now B20 except an arco and a shell with no labeling on their pumps.
Apparently later model trucks are equipped with another filter (water separator?), but I was hoping to hear from others with a similar year dpf equipped truck, and if could provide any tips for when you made the transition from B5 to B20.
Flush the tank first? Add the $600 separator kit? Dont worry and continue hauling around the spare filter under my seat?
Thanks
2007 Ram 2500, 4X4, 6.7
06' Cougar 285EFS
Cummins12V98
on the road
Posted: 01/02/22 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Carry on.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 01/02/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, not an issue.
And not a fan of Arco.
* This post was edited 01/02/22 05:42pm by Grit dog *
2017 Heartland Torque T29
NamMedevac 70
Reno
Posted: 01/02/22 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
no worries with gas. YEP
ScottG
Bothell Wa.
Posted: 01/02/22 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
From RAM TSB 14-007-06 dated August 25, 2006 :
"Models: 2006 - 2007 (DH/Dl/DC) Ram Truck (Heavy Duty)
NOTE: This bulletin applies to vehicles equipped with a 5.9L High Output or a 6.7L Cummins Turbo-Diesel Engine (sales codes ETH or ETJ respectively) that were built on or after March 07, 2006 (MDH 0307XX)."
"- A maximum blend of 5% biodiesel (B5) is acceptable as long as the biodiesel mixture meets ASTM specification D-975, D-975 - grade S-15, and ASTM D6751. A biodiesel fuel blend that is higher than 5% is not acceptable without additional fuel processing because these higher percentage biodiesel blends contain excess amounts of moisture which exceed the water stripping capability of the on-engine final fuel filter. Should a higher percentage biodiesel fuels be used an auxiliary water stripping filter will be required.
- A maximum blend of 20% biodiesel (B20) can be used by government, military, and commercial fleets who equip their vehicle(s) with an optional water separator, and adhere to the guidelines in the Department of Defense specification A-A-59693 (in addition to: ASTM specification D-975, D-975 - grade S-15 and ASTM D6751)
So in short, they feel you need a better water separator.
Diamond c
West ky
Posted: 01/02/22 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Just so you know it’ll make your truck smell like French fries
Posted: 01/03/22 01:55am Link  |  Quote  |  Print  |  Notify Moderator
You sound like that toolbag on Storage Wars who always says YEEEEPP!
I mean, sorry, this was a very helpful post…
Posted: 01/03/22 02:02am Link  |  Quote  |  Print  |  Notify Moderator
OP, there is literally nothing wrong with B20 in your truck. Scott’s recommendation on the TSB is, or maybe was correct. But back then there was no standards on b20.
Worst case and I mean worst case, it might clean up your tank or fuel lines and plug a fuel filter or 2.
And if you’re not running secondary filtration with that OE filter setup, you should be. Your wallet and injectors will be happier in the long run.
Cummins12V98
on the road
Posted: 01/03/22 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Only if he is deleted and If he is doubtful.
Posted: 01/03/22 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Even though he’s not deleted, if he was, what would he have to be doubtful about to make his truck smell like French fries ?
