RV.Net Open Roads Forum: Class C Motorhomes: Exhaust rattle
 > Exhaust rattle
Cruisineasy
Hayward
Posted: 01/02/22 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2011 31' Jayco Greyhawk Class C.
My catalytic converter was stolen so I made a straight pipe to replace it for the time being.(I have the new cat. but don't want to install it for fear of it being stolen again) All bolted up fine. Now I have a rattle at about 1500 RPM. its in the exhaust almost to the end. I checked the whole run and nothing is cracks or touching anything it shouldn't. Any suggestions??
MDKMDK
Free(er), for now, until the next "variant"
Posted: 01/02/22 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Harmonic rattle. Probably due to missing catconv.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
midnightsadie
ohio
Posted: 01/02/22 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hayward like in Wis? inlaw had a cabin on Teel lake loved fishing there. rattle see if theres a heat shield on the muffler ,might be loose.been 20yrs since I was there.
Cruisineasy
Hayward
Posted: 01/02/22 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
No. Hayward Calif. Aww man. Checked everything I could find except the muffler heat shield. I'm bringing it home next weekend. Will check it then.. Hopefully it's not a Harmonic rattle.
jdc1
Rescue, Ca
Posted: 01/02/22 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
After installing the new CAT, weld a few pieces of rebar crisscross to deter thieves.
Posted: 01/03/22 12:54am Link  |  Quote  |  Print  |  Notify Moderator
Doubt it has anything to do with removing the cat, unless you disturbed something else or are putting the exhaust under stress from being hooked back together in a different alignment.
Is it only under load or no load too? If no load, should be eas to find the rattle.
Crawl up under it while someone holds the rpms at rattle speed.
2017 Heartland Torque T29
klutchdust
Orange, California
Posted: 01/03/22 09:23am Link  |  Quote  |  Print  |  Notify Moderator
My first thought was go and check what piping you replaced. Loosen and readjust the clamps and where the pipe goes into the manifold.
I had a hairline crack in a bracket that supported the exhaust up near the manifold.Rattled once it warmed up. Cross bracing on another vehicle.
Gjac
Milford, CT
Posted: 01/10/22 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Could also be a rusted/loose baffle inside of the muffler, at lower RPM it is more noticeable.
Cruisineasy
Hayward
Posted: 01/17/22 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Must be this. Nothing else appears to be loose or cracked. It rattles at 1900 to 2100RPM only.
Gjac
Milford, CT
Posted: 01/23/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
If you hit the muffler with a rubber mallet you should be able to hear the rattle.
 > Exhaust rattle
