2112
Replace your box with something like THIS and use two 6V GC2 batteries.
Get a short cable like THIS to connect the two batteries together in series
2013 KZ Durango 2857
Owens River area
I purchased the battery box 2112 offered. Works great and true to the size given.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BShivers
North Texas
2112 wrote: Replace your box with something like THIS and use two 6V GC2 batteries.
I was going to tell the OP to measure the area where the current battery box is and maybe a larger one can be installed/mounted instead.
2008 WW FS3000 triple axle, 16" wheels, Aluminum siding.
2019 Ford F350 SRW CC/LB 6.7PSD/Auto 4x4
2000 Jeep TJ 4.0/5-Spd 5.5" RE LA lift, 35" Tires 4,440lbs
www.lonestarjeepclub.org
Sandy5
Ohio
Inside area was measured, it can fit bigger and have it narrowed down to a couple of batteries now
pianotuna
Regina, SK, Canada
Sandy5 I sent you a private message some time ago.
Regards, Don
ajriding
st clair
Two 6-volt golf cart batteries!
Easiest and cheapest.
You said no solar. That is the wrong answer. Reconsider. Unless you will drive from outlet to outlet and always be either plugged in or driving (alternator power) then solar will make life so much easier. Solar itself is really simple.
The problem with Marine battery is that it is neither made for starting or for RVs. It is made for a boat. To start the boat motor, go somewhere, turn off motor, then use electric trolling motor for some fishing, then start the motor again and return home. It neither is a good starting battery or a good RV battery, but a compromise, and really only good for a boat.
True deep cycle batts like a GC batt is much more robust and will last longer than a compromised starting/marine battery.
Sandy5
Ohio
pianotuna wrote: Sandy5 I sent you a private message some time ago.
I'm sorry but I just checked my messages and I did not have any in the inbox. Not sure what happened.
pianotuna
Regina, SK, Canada
Sandy5 I've resent it. I was in a weak signal area--so it may not have been delivered.
Vintage465
Prunedale CA.
Just my 2cents. Agreeing with the idea that the best bang for the buck is two 6v golf cart batteries. True 12v deep cycles are really hard to find. Anything that mentions "starting amps" isn't real deep cycle. Knowing you mentioned no solar, but if you plan on doing any type of long term or regular boondocking, solar is really the ticket. Many posters have different opinions on the value of solar, but I believe many people don't really have their solar sorted out correctly(though they think they do). Apart from all that, getting a small 2200/1700 suitcase size genny would charge you batteries up. I run 450w and four 6v Golfer's and never want for power. I think these are great batteries: https://www.batteriesplus.com/productdetails/sli6v210s
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
pianotuna
Regina, SK, Canada
So long as there is no cold weather this would be an excellent battery for boondocking--provided there is sufficient room to install it:
https://shop.signaturesolar.us/products/12v-400ah-lifepo4-battery-by-eg4
