egarant
Mission Viejo CA
I was at at dealer looking at the HOST Yukon and noticed that the black water dump was located above the rear drivers wing at floor level, you are practially eye to eye with it.
I’m imagining that having the dump that high in the air might provide a host of problems (sorry I had to work that pun in).
Anyone dumping the HOST from 5 feet in the air?
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
What's the difference between say 3' up on an avg camper and 5'? (I know, 2', lol) It's not like your trying to lay sewer pipe at a 2% slope.
2017 Heartland Torque T29
jimh406
Western MT
I’ve had a few times that I wanted a valve higher. Just curious, what problems are you thinking being high causes?
Bedlam
PNW
As long as you have the bayonet mount on correctly and slowly ease out the dump valve, there are no problems. I am 6'+ tall so shorter people may need to use a stool if they cannot see what they are connecting.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
mike/kellie
northern calif.
I have a 10" clear extension that twists on at the valve body and my hose clears the side and just drops straight down. I'm 6'3" and it's normal for me.
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
mkirsch
Rochester, NY
If you have people around who might be tempted to stick their mouths over the pipe and open the valve... Maybe reconsider getting a camper at all?
daily double
ketchum ok.
LOL
egarant
Mission Viejo CA
You know **** happens…..and if it does, better to happpen 2 feet off the ground than 5 feet.
It’s a very quirky place for a dump valve if you ask me and the grey tank dump is in another location so you cannot rise you hose after a black water dump with your grey water…..
gbsteph
Grand Prairie, Texas USA
I have a Host Cascade, and with the camper on the truck, the dump valve is at eye level. It's a S***y place for it, but since the tank is mounted in the slide under the dinette, there aren't any options. If the Yukon is like my Cascade, it has a very wide flat tank and doesn't drain very fast or very thoroughly. Takes a good 15 minutes flushing the tank to get somewhat clear water.
MrPhelps
Huntsville, AL
Yep! You Nailed it !
gbsteph wrote: I have a Host Cascade, and with the camper on the truck, the dump valve is at eye level. It's a S***y place for it, but since the tank is mounted in the slide under the dinette, there aren't any options. If the Yukon is like my Cascade, it has a very wide flat tank and doesn't drain very fast or very thoroughly. Takes a good 15 minutes flushing the tank to get somewhat clear water.
- 2018 RAM 3500 Laramie DRW
- 2018 Host Cascade Dual Slide
