RV.Net Open Roads Forum: Fifth-Wheels: Selling Fifth Wheel Hitches - How To
 > Selling Fifth Wheel Hitches - How To
humblerb
houston
Posted: 01/05/22 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Recently upgraded truck to a RAM with Pucks.
My stand-by for resale is FB Marketplace.
So far, zero interest.
I hate Craig's List because of the scammers, but, I placed an ad there recently. Nothing but scammers, so far.
Anyone have thoughts on how to reach potential interested buyers besides these two options.
Are there local "For Sale" pages that target campers?
Thanks,
* This post was edited 01/05/22 01:51pm by an administrator/moderator *
goducks10
There
Posted: 01/05/22 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Try putting it in your brands forum classified. Or other RV sites that may have a classified section.
cummins2014
Utah
Posted: 01/05/22 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
There’s always the option of the frame adapter , I wanted to keep my existing hitch, manual slider. There are three brands of those adapters , cheaper then a new hitch in the event you don’t get your old one sold . The adapter locks on the four pucks , then it works the same as the bed rails, but can be removed along with the hitch or separate.
humblerb
houston
Posted: 01/05/22 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Already talked to B&W about this.
They make an adapter for the Companion.
But, there is not an adapter for the Patriot and RAM trucks.
Cummins12V98
on the road
Posted: 01/05/22 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Sold my older style Companion first day on CL.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Tyler0215
Iowa
Posted: 01/05/22 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
You will probably have better luck selling your hitch in 3 or 4 months.
cummins2014
Utah
Posted: 01/05/22 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you misunderstood me, your hitch was previously mounted to bed rails in your previous truck, this is no different other than its a separate frame that attaches to the four pucks, then you hitch mounts to that .you don't change anything on your hitch . Google Reese 30154 adapter, and you will see what I am talking about , the Reese is the one I have . PullRite ,and Demco also sells one .
They allow for any standard bed rail hitch to work with your puck system without doing anything to the hitch, other then mounting it the same as you did with the bed rails . The nice thing is it removes by unlocking the four pucks ,and remove from the bed .
cummins2014
Utah
Posted: 01/05/22 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Let me add , its a solid connection that frame, it locks to your four factory pucks, and there is no movement or slop . The only movement you will have is the same as you had connected to the bed rails with your four pins, which on mine is nothing I can detect .
Its nice to go directly to the four pucks , and if I was starting from scratch , that's what I would do , but nothing wrong with this setup other than another part to take out if a clean bed is needed. In my case ,I don't bother there is no need for a completely clean bed . IMO its great option, the adapter with already having a hitch , and considering yours is pretty new .
Durb
NW
Posted: 01/05/22 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
I share your frustration with Craigslist. Six years ago, I sold a Patriot on CL the first day. Recently I posted an item under sporting goods and it never went to the top of the list. A sporting goods store had their entire inventory listed (some 2,000 items) and it shoved my post way down to where no one saw it. I had to receive an e-mail to show that I wasn't a bot. Apparently others have found workarounds from doing the same. I ignore any inquiries within the first ten minutes - scams.
If you are posting your hitch under RVs and are not receiving any calls, maybe you need to reconsider your price. Cheap generally sells.
bgum
South Louisiana
Posted: 01/05/22 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Sold mine in 1 day on CL.
