RV.Net Open Roads Forum: Class C Motorhomes: Sprinter alignment
 > Sprinter alignment
two travelers
Smithtown, NY
Posted: 01/07/22 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
We are in the process of buying a new Winnebago View on the Sprinter chassis. In our previous RV's on the F53 chassis it was strongly recommended that a wheel aligment was done. Does that hold true for the Sprinter chassis?
Posted: 01/07/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
If you're buying it new, it better not need an alignment!
Chassis couldn't be more different than a F53, glorified bread truck. Those sometimes need more caster dialed in. You have IFS and it doesn't need a thing except a driver and a place to go!
2017 Heartland Torque T29
bobndot
Posted: 01/07/22 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Any new RV should be aligned . The coach was added to the chassis . If you have it aligned as a ready to roll loaded unit, then your alignment would be most beneficial.
If its new then Sprinter should pay for it.
CharlesinGA
South of Atlanta, Georgia
Posted: 01/08/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
The only adjustments on a Sprinter is toe in/out. Only other way to adjust is camber with shims but you should never encounter a need to do this.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
