RV.Net Open Roads Forum: Class A Motorhomes: Stranded in Marietta, GA
 > Stranded in Marietta, GA
Ro646a
New Boston, MI
Posted: 01/08/22 06:07am Link  |  Quote  |  Print  |  Notify Moderator
We are on our way to Florida in our 99 American Dream diesel with 43000 miles.
After pulling off of I75 in Cleveland, TN for a rest break, I lost pressure to my air brakes.
A local tech was sent out by Good Sam, who looked everything over and said I had been on the brakes too much and I should continue on my way (I'm trying to make this brief).
So we drove another 89 miles to our overnight destination in Acworth,GA.
While maneuvering in the campground my brakes locked up from low air pressure and it took me an hour to build up enough pressure to move it into our space. A mobile service came and found a deteriorated filter in the air dryer, which was to have been checked by a service garage before we left on our trip. They also determined that the governor was defective and replaced it.
When testing it out it first appeared to be working perfectly, with pressure building to 125 very quickly. But after several cycles of test braking, the pressures failed to recover past 60 pounds.
So they checked further and found an issue with a sticking unloder in the compressor. They were unable to get a new compressor until late next week, at which time they had already scheduled work with their regular truck customers. So they did not bill me for the parts, and their labor rate was very reasonable.
Now I am faced with the prospect of having it towed, possibly to a Campers Inn service location nearby (6 miles).
I'm debating whether or not to attempt to drive it there in order to avoid towing. I'm more concerned about potential towing damage to my pristine old motorhome than I am about the cost of towing.
Does anyone have any thoughts they would care to offer?
Thanks in advance.
Roland
1999 American Dream 40 DVS
2011 Jeep Liberty
Roadmaster Sterling Towbar
Brake Buddy
Ranger Smith
Wherever the rig is parked
Posted: 01/08/22 06:26am Link  |  Quote  |  Print  |  Notify Moderator
If it were me I would call around and get a truck facility to repair it and NOT a Campers Inn. They are generally not truck repairers
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
JRscooby
Indepmo
Posted: 01/08/22 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I have a hard time standing under the issue getting a compressor. On a truck, changing one is not that hard on side of road, but might need a curved 12 pt wrench for bolt or 2.
Before I would tow, assuming you have a genset, I would hook a electric compressor to the tank. Driving without a dependable air supply? NO
haste maker
alabama
Posted: 01/08/22 07:15am Link  |  Quote  |  Print  |  Notify Moderator
From what you have said, sounds like you may have a air compressor governor going bad, if this is the problem only way to fix this is replace the governor...most good 18 wheeler truck repair shops can do this job.
Retried Teamster
2007 Allergo
Ranger Smith
Posted: 01/08/22 07:18am Link  |  Quote  |  Print  |  Notify Moderator
In his post he said they replaced the governor.
oldave
Tx
Posted: 01/08/22 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you have a tow car get the part number, take lots of pictures, and
go looking for one.
Acworth/Marietta Ga is right there at Atlanta so you should be able to find plenty of
large truck ( semi ) parts stores.
The post above using a small 120v compressor is what I would do, then drive it to
a truck shop
JRscooby
Indepmo
Posted: 01/08/22 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Just another thought; How cold is it there? How long has it been since you drained air tanks to check for water?
Damp air, going thru valves where the pressure can ice up cause problems to make you pull your hair out.
Ro646a
New Boston, MI
Posted: 01/08/22 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Freezing temps at night.
The mobile tech went through all the air components when be was here. They are pretty confident that I need a compressor.
My greatest fear is my RV getting damaged by towing. The other concern is time. Nobody so far can fit it into their schedule.
JRscooby
Indepmo
Posted: 01/08/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
For decades most trucks have had air dryers from factory. If they are maintained, airline freeze-up is not a issue. In the years before I retired I noticed a large percentage of pro drivers did not understand opening valves in the bottom of the tank to check for moisture buildup is a good idea. Bet most RVers never knew. There is a good chance, IMHO, that a tech from the south has never dealt with a system freezing up.
The outside temp can be well above freezing, and ice still form where air moves from high to lower pressure.
Look at the system. Trace the big air line from compressor to the first tank, it should have a petcock, (Maybe auto drain valve, maybe valve with lanyard) Use your propane torch, heat that tank near that valve until you can touch, but can't hold with bare hand. Open the drain (If auto, may need to remove. If you have pressure in tank unscrew part way to let it leak. Don't let it hit you if it blasts out.) If you don't get any water out, then I might think about a bad compressor.
haste maker
alabama
Posted: 01/08/22 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Correct I missed that...
