The WFCO is perfectly fine to float a lead-acid battery in the cold of winter. If still concerned check the battery voltage after a week of no use to see you are in the 13.2 to 13.6 range.
Normally I do take them ( 4 6volts) out but as I get older for some reason they get heavier!!
And if Biden can figure it out that an un-jabbed Canadian snowbird isolated in his trailer is no more dangerous than the millions streaming in from the south to stay.
Maybe will drive south for two months and spend some money.
ivbinconned wrote: Normally I do take them ( 4 6volts) out but as I get older for some reason they get heavier!!
Get lighter batteries. You seriously want to turn this into politics?
