RV.Net Open Roads Forum: Tech Issues: Will my WFCO 55 amp over charge?
 > Will my WFCO 55 amp over charge?
ivbinconned
highway 16
Posted: 01/08/22 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Or can I leave it plugged in all winter as a maintainer?
This is on a 09 Cedar Creek 5th.
Ram and 34 ft Cedar Creek
theoldwizard1
SE MI
Posted: 01/08/22 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I would not.
Near Mammoth, California
Posted: 01/08/22 09:30am Link  |  Quote  |  Print  |  Notify Moderator
A thirty watt solar panel with a decent controller will do the job much better. Still need to check battery water level every month however.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bgum
South Louisiana
Posted: 01/08/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Get a 10 or 15 watt 12v solar maintainer and hook to battery. Disconnect the negative wire and turn off your converter.. Your battery will thank you
ivbinconned
highway 16
Posted: 01/08/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Don’t know how well a solar would work here in the frozen short sun lite days of the north.
2oldman
NM
Posted: 01/08/22 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Bring batteries in and keep them warm. They like that.
time2roll
Posted: 01/08/22 10:17am Link  |  Quote  |  Print  |  Notify Moderator
The WFCO is perfectly fine to float a lead-acid battery in the cold of winter. If still concerned check the battery voltage after a week of no use to see you are in the 13.2 to 13.6 range.
675w Solar pictures back up
Boon Docker
Posted: 01/08/22 10:55am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
ivbinconned
highway 16
Posted: 01/08/22 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Normally I do take them ( 4 6volts) out but as I get older for some reason they get heavier!!
And if Biden can figure it out that an un-jabbed Canadian snowbird isolated in his trailer is no more dangerous than the millions streaming in from the south to stay.
Maybe will drive south for two months and spend some money.
2oldman
NM
Posted: 01/08/22 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Get lighter batteries. You seriously want to turn this into politics?
