RV.Net Open Roads Forum: General RVing Issues: Propane question
 > Propane question
RandandDoug
East Texas
Posted: 01/08/22 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Was asked this in a campground, and while I think I have all the answers, I am not at all sure i am ever right.
Fifth wheel with two propane cylinders, if running low, can someone hook up a small, like blue rhino bbq tank to one of the hoses to get through a night, and should it be hooked up like regular. Meaning leaving the switch to the large tank as usual, and letting it switch over if it runs out, using the small tank as a backup?
Thanks
bgum
South Louisiana
Posted: 01/08/22 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Yes and yea
philh
Belleville MI
Posted: 01/08/22 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have two 40lb onboard tanks and have a 20lb spare that is used for a firepit too.
2oldman
So Cal
Posted: 01/08/22 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sure, in fact I use only the BBQ tanks because the 7 gallon ones are too heavy.
Posted: 01/08/22 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Yes you can. Also if you have the proper adapter you can do the same with a motor home..... Done it a few times. (Extend-a-stay or Stay-a-while are the names of the adapters)
NOTE: You don't need an adapter with a Trailer though you may need an overturned bucket to raise the smaller tank to the proper height. (or a few slabs of wood or .. well most anything)
Note 2: On a motor home I've seen some home made "Adapters" to allow external Propane feed.... SCARY.
rhagfo
Portland, OR
Posted: 01/08/22 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
We have 3 30# tanks and a 20# for BBQ and as a backup. We the third 30# after dealing with a nine day power outage. During the outage we placed the 20# on a couple Lego levers and took both 30# so they were both FULL.
time2roll
Posted: 01/08/22 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
When you are under 50% (one cylinder empty) the propane regulator should have a red indicator. The lever is pointing to the empty. Fill the cylinder and move the pointer. Repeat as needed and you will never run out. Check daily during high usage of the furnace.
Otherwise yes any cylinder that has the correct fitting can be attached. 10lb, 100lb, 250lb, 500+ gallon all work the same.
675w Solar pictures back up
jdc1
Rescue, Ca
Posted: 01/09/22 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I have an older couple (California fire victims that lost their home) living in my 5th wheel right now that do exactly what you are asking about. Our temps are 30-50* now, so the furnace stays on most of the night. They have 3 different size tanks sitting out there they use.
afidel
Cleveland
Posted: 01/18/22 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
What are your propane and electric rates? For me here in Ohio with electric at $.12/kWh and propane at $4/gallon it's 50% cheaper to heat with electric than propane.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
CavemanCharlie
Storden,MN
Posted: 01/21/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I think that is kinda rare. Here in southern MN electricity heating is never cheaper then propane. (Unless you are getting the electric for free at a campground.)
I'm really bad at math but, I wonder if you are doing your math right ? You need to know how many BTU's you are getting for those prices to do a accurate comparison.
 > Propane question
