RV.Net Open Roads Forum: Fifth-Wheels: LED RV Awning Party Light with Mounting Channel
 > LED RV Awning Party Light with Mounting Channel
klr650goldwing
minnesota
Posted: 01/08/22 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone mounted LED rope lights under their awning on a 5th wheel trailer? As an aftermarket product how did you power it?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
philh
Belleville MI
Posted: 01/08/22 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
On my TT, I took LED strip and glued it the the roller and ran 12V power with a 4 pole connector. It worked good, until it didn't.
2112
Posted: 01/09/22 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I installed the RecPro similar to THIS.
Look at the pictured reviews on that link. See how one guy wired them into his porch light wiring. Another guy had to run his own 12V wires. I'm just providing some ideas
* This post was edited 01/09/22 08:03am by 2112 *
2013 KZ Durango 2857
austinjenna
Columbus, Ohio
Posted: 01/17/22 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I put on the LED strip lights on the awning mount where it attaches to the trailer. Then ran the wire down through the awning arm mount, there is a plastic cover that pops off once the arm is extended. This is the same place they run their wire for the powered awning. I have the connector just coming out of the bottom of the awning arm maybe 2 inches or so.
I then ran wires from the battery (use a fuse) to underneath where the propane tank is mounted right by the awning arm, I have extra length and just coil it up and when I need it, I just uncoil it and plug it into the connector at the awning arm
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
