RV.Net Open Roads Forum: Class C Motorhomes: Sea Foam stabilizer
 > Sea Foam stabilizer
EMD360
Arvada, CO
Posted: 01/08/22 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I’d try sea foam for winter. I had read general accounts-fill up and add a can then run long enough with the generator running to get the treated gas through the system.
I bought two cans to try but the directions are confusing me. Calls for one ounce for every gallon of gas. 55 oz? Really? Then directions are to add to a low tank of gas for a higher concentration as it runs through the engine. Can’t do that I filled it for the winter already.
Is one can enough for storage? Do you really add 4 or more cans when storing your RV?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
bgum
South Louisiana
Posted: 01/08/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Put 1 oz for every gallon of gas in your tank. Run the engine and generator about 15 minutes shut them off until winter is over or you need to exercise genny.
In your case this would be 4 cans of 16 oz each for a 55 gallon tank.
bobndot
Posted: 01/08/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Its less expensive to use Startron. Works equally well.
Posted: 01/08/22 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Next year, don’t fill your tank before winter. That’s another old wives tale. You don’t need to worry about moisture in the tank unless there’s some extenuating circumstances.
And even if there is a bit of condensation, the ethanol in regular gasoline will eat it up no problem.
2017 Heartland Torque T29
dieseltruckdriver
Black Hills of SD
Posted: 01/08/22 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Seafoam is a petroleum based product, so you can add more if you want. It won't hurt a thing, and it is a good gasoline stabilizer. I have used it for over a dozen years when I switched from Stabil.
You really should add it before you fill, as with any additive so it gets mixed well when you are filling your tank.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
AJR
Close to Madison Wisconsin
Posted: 01/08/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
So what happens if you use less than the recommended dose? Like maybe half of it.
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
dieseltruckdriver
Black Hills of SD
Posted: 01/08/22 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmm. I don't know. Maybe it works half as well?
bgum
South Louisiana
Posted: 01/09/22 06:54am Link  |  Quote  |  Print  |  Notify Moderator
What happens if you only take 1/2 your medications each day.
Posted: 01/09/22 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Roflmao
jdc1
Rescue, Ca
Posted: 01/09/22 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I wonder how many car, tractor, boat, and plane dealers run around their lots putting Seafoam in the products sitting there? Hmmmmm.
