RV.Net Open Roads Forum: Class C Motorhomes: Sea Foam stabilizer
 > Sea Foam stabilizer
4x4van
California
Posted: 01/11/22 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
path1 wrote:
here's my reasoning. When these things are made, the installation of the fuel line goes from gas tank to generator, holes are drilled in top of fuel tank for the generator fuel line. Those drill fillings fall to the bottom of fuel tank. but newer units are plastic, and don't know if material of tank makes a difference. My tank is alum After years of being sitting at bottom of fuel tank they sort of get stuck. Add something to clean the system such as seafoam and they get unstuck and get sucked up in fuel line and make there way to the engine fuel filter and plug it up. Then the fuel filter goes into "bypass" mode and then plugs of the injectors. More specifically the little tiny screens that some injectors have (such as my 5.4 ford triton.) Injectors at the time $75 each or spend about 4 hours with a bright light and twizzers and magnifying glass picking out junk. Does not include time learning how coil over plugs work and getting to injectors removing and installing back in.
There's so much wrong with this post, I don't even know where to begin. But suffice to say that fuel tanks are not "drilled" for the installation of generator fuel lines. If you had **** in your tank, it was not from the installation of the generator fuel line, and it didn't get "stirred up" by Seafoam. I also don't know of any fuel filter with a "bypass" mode.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 TriZinger, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
AJR
Close to Madison Wisconsin
Posted: 01/11/22 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
An almost empty (1/8 maybe) large gas tank filled with non-ethanol gas has started every gas engine I have ever owned for many years two or three springs down the line of no use.
Ethanol is the issue being discussed.
Don’t use it on your last tank or two of gas and no problem come spring. Yep, run the generator, right before you put the camper to bed, for an hour with real gas going to it.
I know it may cost more. But piece of mind, for me, has no price.
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
Gjac
Milford, CT
Posted: 01/12/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
EMD360 wrote:
So I don’t need the sea foam at all unless I wanted to clean the generator. We are leaving Feb 12th. I have no idea how to draw sea foam into just the generator. Thanks for the tip but that will take way more study. Guess I’ll just keep the sea foam for next year. And buy two more cans then. And put it in before I fill up. Good advice.
Just remove the hose that draws from the tank and insert 3 ft of the same ID hose into a can that you can mix the Seafoam with gas. Seafoam will keep the carb from gumming up over the winter months as will Stabil and other products. I like Seafoam because it does both. You are not talking years of non use only over the winter months.
RambleOnNW
Pacific Northwest
Posted: 01/12/22 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I use Stabil in the MH tank prior to filling with gas at the specified rate of 1 Oz per 2.5 gallons of gas (22 oz. In 55 gal. Tank) when not using it in the winter. I do take it out for a drive and run the generator once a month. Never had a problem. Also use Stabil in a Honda EU3000IS generator at 2 oz. per 2.5 gal. of gas also in a couple of gas cans. Recently changed out the gas after 18 months and dumped the gas in the car tank. Had no driving issues.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
NamMedevac 70
Reno
Posted: 01/13/22 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Seafoam is great stuff. I can run 100 mph after drin
* This post was edited 01/13/22 02:27am by NamMedevac 70 *
Posted: 01/13/22 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Drunk posting?
2017 Heartland Torque T29
