RV.Net Open Roads Forum: Tech Issues: Water pump runs continually
 > Water pump runs continually
IamSiler
Georgia
Posted: 01/09/22 10:25am Link  |  Quote  |  Print  |  Notify Moderator
We purchased a used MH Sand are on our first trip with it. We are new to RVing as well. The water pump runs continuously. We watched a YouTube video about getting an open valve closed and went through the steps twice and it hasn’t helped.
Is there anything else we can check before we take it in to the repair shop?
way2roll
Wilmington NC
Posted: 01/09/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Only a few things will allow a water pump to run continuously - an empty fresh water tank, a bad check valve, or a leak.
Do you have water in your fresh water tank?
Are you hooked up to a water connection? And if so are you leaving your pump on?
Are your valves set appropriately?
Is there evidence of a leak somewhere?
Was there any sort of pre-delivery inspection done on this MH?
By the way, did you get your light switch sorted out?
dougrainer
Carrolton, Texas
The most common cause of this type problem is, you have your City Water tank fill valve OPEN. This will cause the pump to continually recycle the water. I also assume it will turn OFF when requested to do so? From the Pump On/Off switch?. Now, if you are connected to City Water and that valve is left open, your fresh tank will overflow. You are new to the forum. ALWAYS, list Year/Make/Model/Chassis of RV when posting. Or put this info in your profile. Doug
MFL
Midwest
Posted: 01/09/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
A few basic questions
Is there ample water in the fresh tank?
Are you allowing enough run time to fill water heater?
Is the valve for winterizing in the proper position?
Are you opening a single faucet to allow air to escape?
A knowledgeable friend, with more RV experience may be able to help with diagnosis, rather than taking to dealer.
Jerry
enblethen
Moses Lake, WA
Posted: 01/09/22 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Verify the fill valve is in the run position, if equipped.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IamSiler
Georgia
Posted: 01/09/22 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Liste the info I could in the profile. Some of their selections are outdated and don’t have years past 2020
Thermoguy
Graham, WA
Posted: 01/09/22 11:26am Link  |  Quote  |  Print  |  Notify Moderator
I am unfamiliar with your rig, but if you are connected to city water, turn your pump off. You only use your pump when you are not connected and using your fresh water tank. By hooking to city water, you bypass your pump and water tank.
IamSiler
Georgia
Posted: 01/09/22 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Problem solved!! I was right. User error
Thank you all for the responses
IamSiler
Georgia
Posted: 01/09/22 11:45am Link  |  Quote  |  Print  |  Notify Moderator
This solved the problem. We are newbies so thanks for your patience
IamSiler
Georgia
Posted: 01/09/22 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Well now we are back to our original problem. When we turn the city water faucet on it leaks out around where the water filter is. I’m sure there is probably some kind of tank there but I don’t know what it is called.
I forgot that was why we turned the faucet off.
