RV.Net Open Roads Forum: Tech Issues: Water pump runs continually
 > Water pump runs continually
Thermoguy
Graham, WA
Posted: 01/09/22 12:24pm Link  |  Print  |  Notify Moderator
Can you post pictures or something? Might be a bad seal, the filter is not screwed on tight enough, or something completely different. You will need pictures for people to understand what you are describing.
2112
Posted: 01/09/22 04:38pm Link  |  Print  |  Notify Moderator
What was the resolution to the lights? Don't leave us hanging. Inquiring minds want to know
2013 KZ Durango 2857
2112
Posted: 01/09/22 04:42pm Link  |  Print  |  Notify Moderator
Use This Link to post pics.
It will generate some code. Copy and paste the code into your post as-is.
IamSiler
Georgia
Posted: 01/09/22 05:21pm Link  |  Print  |  Notify Moderator
Lol sorry…
He had turned the faucet to the city water off because it pours out of some other tank. From what I’ve read it may be a bad valve on the water pump or something . I thought the problem was resolved when I turned the faucet on but then the water pours out so something else is definitely wrong.
way2roll
Wilmington NC
Posted: 01/10/22 06:40am Link  |  Print  |  Notify Moderator
If you are leaking water when connected to a water source, you need to trace the leak. It's either a connection in your hose and filter, or you have the valves for city/fresh water in the wrong position and are overflowing your tank. If your valve is in the correct position it is possible you have a bad valve. This is odd though because if your tank was full and overflowing your pump would not continuously run - unless you have a leak.
Given the limited information, I am going to guess you have a leak somewhere in the supply line. This guess is based on the fact that your water pump continues to run. It wouldn't do that if your water tank was full and overflowing.
What does the reading say on your fresh water tank?
Are your winterization valves in the proper position for use?
Posted: 01/10/22 08:34am Link  |  Print  |  Notify Moderator
IamSiler wrote:
Lol sorry…
Your descriptions are confusing, some is your terminology. IE don't know what a city water faucet is.
If reading right, you got the pump working right but now have leak from somewhere.
Is it possible your city water connection also can fill the FW tank (not common, afaik), maybe by turning a valve to divert from the plumbing system to the FW tank and it's just overfilling the fw tank?
The FW tank will freely overflow if overfull. Its designed to do that
2017 Heartland Torque T29
dedmiston
Coast to Coast
Posted: 01/10/22 12:55pm Link  |  Print  |  Notify Moderator
Let's all try to remember that we were all new here once upon a time. A lot of the stuff that feels like common sense to us was confusing until we figured it out.
A little patience and understanding for the newcomer will go a long way.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Posted: 01/10/22 01:50pm Link  |  Print  |  Notify Moderator
It appears everyone is being extremely helpful thus far, however the OP's posts come in fits and spurts with terminology Im not certain anyone understands.
I'd suggest the OP find someone whos camping and ask them to take a look, as we're not getting very far with his/her descriptions.
dedmiston
Coast to Coast
Posted: 01/10/22 10:11pm Link  |  Print  |  Notify Moderator
I disagree. Do unto others, man. Try to remember how it felt when you were new. Give the guy some slack and let him get his feet under him. It just takes a minute to be kind. Or keep scrolling.
Posted: 01/11/22 11:24am Link  |  Print  |  Notify Moderator
Buddy, not sure why you're in a tiff over this one. The OPs 2 threads have both been civil and folks trying to be helpful including multiple suggestions to find a real live person nearby to help them through their issues. I suggested this because they appear unable to articulate, even remotely effectively, what their issues are.
He!!, I even PMd the OP, who got right back to me saying they had spotty service (but managed to reply to my PM?? yet no response to the outstanding questions from folks trying to help them).
The biggest issue is "we" may be trying to be "too" helpful, I suppose. Based on the OPs posts it sounds like they are on the road, somewhere, and cant turn off their lights without the fridge going dead and cant use the water because of who knows what.
Yet, after asking multiple questions and multiple responses, they go radio silence.
Maybe it's just me, but I expect that if I'm asking for help, I make every effort to respond completely and appropriately to help those that are trying to help me.
Best of luck to them.
Cheers!
