RV.Net Open Roads Forum: Fifth-Wheels: Hitch maintenance
 > Hitch maintenance
mlh
Louisiana
Posted: 01/09/22 11:03am Link  |  Quote  |  Print  |  Notify Moderator
How often does everyone get under the truck to check the torque of thebolts of your bed rails and frame brackets?
2021 Ram 2500 Crew, 6.4, 4x4
2022 Cherokee Arctic Wolf 287BH
B and W patriot 18k slider.
MNRon
Tennessee
Posted: 01/09/22 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Had hitch installed in 2014, never even thought about it until this post…7-8yrs, ~60k miles pulling 14k first half, 16k second half…not planning on thinking about it again
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
TXiceman
Full Time RVer
Posted: 01/09/22 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
About every 2 years and have not found a loose one yet....
Ken
Amateur Radio Operator.
mlh
Louisiana
Posted: 01/09/22 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. Just wasn’t sure if it was something that needs to be checked often or just once a year or so.
valhalla360
No paticular place.
Posted: 01/09/22 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Never seen or heard of anyone doing it for a 5er or standard receiver hitch.
Also don't check the bolts holding the bumper, motor mounts, truck bed or a host of other items bolted on the truck.
Only items where I've heard it suggested is for lug nuts but even there, it's typically after the first 50miles and then never again (unless you remove the tire).
I suppose if you just installed it, after the first trip doing a quick check won't hurt.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > Hitch maintenance
