jdc1
Rescue, Ca
Force water in the opposite direction. You can do that using one of these;
https://www.amazon.com/Valterra-Degree-Reverse-Attachment-Trailer/dp/B008O9DV78/ref=sr_1_3?crid=Q988JVIA36TJ&keywords=rv+backflush+waste+attachments&qid=1641843453&sprefix=rv+backflush+waste+attachments%2Caps%2C141&sr=8-3
campermama
Here and There
UPDATE!!!
I got a gallon of full strength antifreeze and poured it down the drain, opened tank valve and let sit all day, then opened main drain valve and the tank emptied!!!!
Thank you all so much for all the ideas/advice!!!!
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
MFL
Midwest
Thanks for the update! Glad you got it thawed out.
Is there something you can do different, to keep this from happening again? Don't know where you are at, but hopefully the extreme temps are not the norm.
Jerry
campermama
Here and There
It shouldn't happen again, the main dump valve was frozen so I started using a hair dryer to thaw it, half way through I thought I would see if water would come through yet so I pulled the tank valve real fast open close. So pretty sure that is how water got in there. Temps are staying very cold here but I am heading south next week!
