RV.Net Open Roads Forum: New RV USB plugs, what amperage are they?
 > New RV USB plugs, what amperage are they?
TurnThePage
North ID
Posted: 01/09/22 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Many new(ish) devices require the higher powered, 2.1-amp USB plugs. On the flip side, most of the plugs I've seen in RVs I believe are under an amp. Anybody knowledgeable on this subject? Is the RV industry keeping up with technology?
2015 Ram 1500
2004 Pioneer 18T6
Second Chance
Wherever...
Posted: 01/09/22 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
The ones in our Solitude fifth wheel appear to be 2.4A:
USB charging port
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
CA Traveler
The Western States
Posted: 01/09/22 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Given the variety of USB standards it seems unlikely that there can be any RV standard. If for example you are asking about a USB-C 3.0A power source you could install the USB connectors needed for your devices powered from 12V DC or 120V AC adapters as desired.
2014 Grand Cherokee Overland
Bob
time2roll
Posted: 01/09/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Like everything else.... test it and plan to upgrade if needed.
675w Solar pictures back up
TurnThePage
North ID
Posted: 01/09/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have only seen USB type A female ports in the RVs I can afford to look at. USB-C ports would answer my questions right up front. Aside from that, I don't care what standard they choose, if they would just share what it is. I don't see that info mentioned anywhere. I'm currently shopping Cougars, Imagines, and Outdoors RVs. But I haven't seen that info anywhere yet, not even on the motorhomes I've looked at. Yes, I could install the ones I want, but then I would need to know if their wiring is up to snuff. This is just regular info that should be available, right?
CA Traveler
The Western States
Posted: 01/09/22 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Cigarette plug to USB C adapters are available.
There are new standards evolving that a device could use. Right now there are USB C PD (Power Density) ones that use 20V or 48V for more power.
You could also use a inverter for 120V AC and adapters that come with the devices.
TurnThePage
North ID
Posted: 01/09/22 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate the suggestions and am pretty versed on what's available in the aftermarket. I was just wondering if anybody was knowledgeable about what's typically installed these days.
Hope everybody's new year is off to a better start than the last couple!
Happy Camping!
NamMedevac 70
Reno
Posted: 01/09/22 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
great question. I am watchful waiting.
afidel
Cleveland
Posted: 01/10/22 12:33am Link  |  Quote  |  Print  |  Notify Moderator
Personally on my last trailer I just tapped a 2 way cigarette adapter off the slide cabling before the switch, biggest 12V lines in the rig and right near the biggest flat surface not taken by other uses. On my new rig I'm planning to put in a couple cigarette adapters directly off of unpopulated 12V slots in the distribution center and installing them in the tv alcove above. I'm thinking a single high amp one to run an inverter for the tv and anything else I want to run on 120V off-grid and a 2 way or 3 way for chargers.
BTW to answer you question for my rig it's probably 2.4A, I'm running a USB powered wifi router and my home automation system off it, each calls for ~1A steady state, peaks can be higher so I put a $10 USB power pack inline.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
way2roll
Wilmington NC
Posted: 01/10/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
No idea the specs of our USB ports in the FW but they are awful. Takes forever to charge my phone so we just don't use them. I'd replace them if I thought it was worth it but we either use the truck or just use the AC wall adapter.
