Johnnybgood
Illinois
We are actually headed to North Dakota. In researching reflectix we found that by itself it’s r value was 1. By adding air space of about 1/4 inch it increases to 3. We put corrugated cardboard and reflectix under our mattress and it works great. + whatever number were on for the heated mattress pad. Add a down comforter and a wool blanket. You will sleep toasty warm. We generally turn our heat down to 60 at night and sleep well. Safe and comfy travels to all.
JimK-NY
NY
I completely turn off the heat at night. By morning the temps in the camper are often down to 40 degrees or less. I have had no issues using a hot water bottle to get started and several fluffy blankets.
If anyone is interested Costco is currently selling Pendleton sherpa fleece blankets that are extremely warm and only cost $35. Two or three of those should do it down to really low temps.
Camper_Jeff_&_Kelli
Seattle
I'm south of Medford Oregon tonight. It's 35 outside. My mattress insulation project seems to be working but, I'm turned around in bed, feet forward by the front window, head at the foot of the bed. My head is comfortably warmer now and my feet don't mind the cold. Furnace on for 60 degrees but the cabover bed area has much greater exposed surface area to i ternal volume than the rest of the camper and as such, is susceptible to much greater and faster temperature swings. The extra blanket is doing the trick.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
JoeChiOhki
Sauvie Island, OR
Camper_Jeff_&_Kelli wrote: Reality Check wrote: Interesting thread.
We camp alot in the winter. Just spent 4 days in 0-5F degree weather. Never really had an issue with the mattress or cold. Condensation, can be an issue, but it's a super easy solution. Got to have air movement. I usually just crack the kitchen window a bit and open the bathroom vent slightly (fan stays off). An example, two days into the camp, no condensation at all, windows being the best indicator. Cooked breakfast for three extra adults and two kids (squeeze them in..!) and after a bit over two hours, the windows were covered in condensation. It's our breath. Turned the fan on when they left and half hour later, camper was cleared up.
A suggestion for under the mattress. One needs air movement but most can't afford the height loss. Pick up a piece of Miradrain or equivalent. It's a composite drain product, and it will keep an open airway under the mattress. About 1/2" tall, plastic and fiber, water proof.
Last... skip the flannel sheets. They're only warm 'after' you get in and warm them up. Go fleece. Tell them I sent you...! There is no comparison.
The foundation dimpled sheet would work very well. I actually have a roll of it in my shop.
I talked with Joe Chi Ochi, Matt, who foil tape sealed a foam board down in his cabover and wrote a post about it back about 2007 with good results. I'll keep an eye on the current setup to see how it performs. Rather than the foil tape, there is a PVC tape which is stronger and more flexible than the aluminum tape. I'll keep you posted on results.
Work well for many years, never had any moisture issues.
We did however, also install carpet foam and full home carpet over that foil face polyisocyanurate foam and around the perimeter of where the mattress came in contact with the walls.
We also used a 10" thick Polyurethane foam mattress vs inner spring, which added another layer of insulation between the floor and the occupants.
With the Amerigo, we have 3" of R22 fiberglass insulation beneath the floor of the cabover and a 3/4" plywood deck on top of which our mattress rests, so I didn't need to do the same trick this go round.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
c.traveler2
Moreno Valley,Ca.
I liked your video and it's a reasonable solution for what your trying to resolve. In the Spring write a update on your mod.
2007 F-250 4x4 /6.0 PSD/ext cab/ 2020 Bunduvry
Lance 815/ 85 watts solar panel (sold)
2020 Bunduvry by BundutecUSA
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
