beergardens
Calgary, Alberta
You need to open both doors and the hood fully for diagnostic access, then disable all the door/hood ajar switches so the vehicle thinks they’re closed. Then you need to disconnect the battery and put your ammeter in series. After that is all done, you need to walk away for an hour so everything times out, keeping in mind that if you open a door or a connection, you’re going to wake everything up again and your reading will no longer be accurate.
BFL13
Victoria, BC
beergardens wrote: You need to open both doors and the hood fully for diagnostic access, then disable all the door/hood ajar switches so the vehicle thinks they’re closed. Then you need to disconnect the battery and put your ammeter in series. After that is all done, you need to walk away for an hour so everything times out, keeping in mind that if you open a door or a connection, you’re going to wake everything up again and your reading will no longer be accurate.
Goodness!
It also has two back half doors, but anyway, except to open at first to pop the hood why do I have to leave the doors open and then fool them? Why not just close them?
Where is the hood's ajar switch? Edit--like this with the plug-in?
(no idea why it is in Spanish )
https://www.amazon.com/-/es/Dorman-820-2........0-hood-latch-assembly%2Caps%2C150&sr=8-3
I can use clamps on the meter leads so I can leave it connected like that.
To save meter battery can I turn the meter off and it is still making a path in series or does it have to be left on reading amps while waiting that hour?
edited 01/11/22 10:03pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Krusty
Calgary, Alberta,Canada
Beergardens is correct. Connect amp meter in series, or I just use a jumper wire until I am ready to watch the draw. My meter times out after several minutes and it will open the connection when it does. You do not want to break the connection. Let it sit undisturbed for an hour so the modules go to sleep. It shouldn't draw more than about .050 amp (50 milliamps) after this. You want the doors and hood open so you can disconnect fuses to isolate the draw. Just use a small screwdriver to latch the door latches fully to simulate the doors being closed.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
BFL13
Victoria, BC
I can't see any wires to the hood latch like in the above link. Can't see any push-in switches.
How does the jumper work to preserve the connection when you go to do the meter in series? If you leave the jumper there, don't some of the amps go down that wire instead all of them through the meter?
Edit: once the meter is on, you can remove the jumper?
Meanwhile, today the voltage is down to 12.35 after four days parked, dropping almost 0.1 a day. So I can leave it parked off-grid for a long weekend and a bit and it will still start.
That leaves the battery less than full for long periods and it will sulfate. If I bring it up each time it gets low at home, that would be deep-cycling the starting battery, and letting it sulfate, so the way things are I need to plug in the maintainer when the truck is not being used. I can live with that if need be.
Plan is to recharge the battery today and keep it charged. AFAIK its state of charge does not affect the mystery draw to be tested for again tomorrow.
edited 01/12/22 02:04pm by BFL13 *
BFL13
Victoria, BC
Got started on this. Leaving hood up, can't find any ajar switch.
Tried to leave driver's door open (only door that needs to be open to get at the fuse boxes in there) and jam the open switch with a screwdriver (no luck there) and with other things still no luck. Leaving it closed for now to at least get the amps reading an hour from now.
There is a sort of spring- loaded lever above the door latch which is mounted in the end of the back half door (which is a "suicide" facing door that opens from the front end). There is also a push button in the end of the driver's door higher up. I am guessing it is the lever thing that needs "fooling" based on advice I got above, but I have not found a way to jam it yet.
I rigged up a jumper wire between the neg post and the disconnected neg terminal, and have a wire nut in the middle of that wire. I have the meter set to amps with a clamp fixed to one lead and the other lead jammed in the neg post so I can clamp the meter to the neg wire terminal as desired.
So with the jumper wire connected via wire nut, voltage is 13.2 (from just having the maintainer taken off), and amps on the meter is zero.
With the meter still connected and showing zero amps, when the jumper wire nut is taken off the amps jump to 0.20 amps. I don't know what happened to that 0.74 amps from before.
So back later with the amps reading I get after the hour long wait.
EDIT--it only dropped to 0.18 amps. Not clear I got anything done. Probably messed up the procedure somehow. Anyway, I will just leave the battery maintainer on at home and live with that.
Thanks all for the info and tips on this whole thing. Back to regular programming.
edited 01/13/22 12:47pm by BFL13 *
travisc
Pacific NW
Take a look at this video on YouTube watch Wes work, he’s got a channel as a small country mechanic and fixes all kinds of things this video applies directly https://youtu.be/xEEtmdUckvI
Winnebago Access 24V
BenK
SF BayArea
Turn off any "automatic" anything
Headlights, BlueTooth, navigation, monitir, etc
They *ALL* check in on a regular basis and some have a "power up" & wake process
-Ben Picture of my rig
garyp4951
TN
Check the body of the alternator for voltage, or remove the hot wire to it.
I had one that was bleeding voltage from the connecter post to the body.
garyp4951 wrote: Check the body of the alternator for voltage, or remove the hot wire to it.
OP already has an issue in this area likely, so great suggestion.
Was suggested, but not responded to or even acknowledged.
But sounds like his attention span is as short as his will to fix this problem. Been more time spent on this thread trying to help him diagnose it than he’s spent trying to fix it. And apparently he’s thrown in the towel after 1 attempt.
2017 Heartland Torque T29
BFL13
Victoria, BC
travisc wrote: Take a look at this video on YouTube watch Wes work, he’s got a channel as a small country mechanic and fixes all kinds of things this video applies directly https://youtu.be/xEEtmdUckvI
https://www.youtube.com/watch?v=xEEtmdUckvI
Yes the parasitic draw part is close to what I was trying to do.
Lots of good ideas coming in, but I have given up now that I know I can operate with it as is. Way too complicated for little me and my multimeter!
Thanks all for trying to help.
