BurbMan
Indianapolis, IN
Lantley, good idea, I didn't think to check Hensley. The air ride is interesting, does it really improve the ride?
Regarding removal, maybe not plywood, but drywall...you pile a few sheets of drywall on top of a hitch and it won't look like much when you get it home. Also, DW is into restoring furniture...she's excited to have a truck vs. the old Suburban because she can bring home bigger stuff now... ![rolleyes [emoticon]](http://www.rv.net/sharedcontent/cfb/images/rolleyes.gif)
I'm thinking an engine hoist make hitch removal easy, right?
2008 Heartland Big Country 3250TS
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
JIMNLIN
Oklahoma
The hoist is a good idea but needs a hard surface if you plan on rolling it around.
Some use a small elect hoist or a come-a-long dropped down from rafters in the garage.
My hitch is stored hanging from 12' tall truss ribs and a come-a-long in my trailer shed.
rhagfo
Portland, OR
Thermoguy wrote: The puck system requires your truck has the pucks installed - newer trucks. Did you post what year your truck is?
The second one you posted is the same that I have. I also have a gooseneck trailer, so it requires a B&W turn over ball to also be installed. The advantage is you have 2 hitches if you need that. The other advantage is that when you take the 5th wheel hitch out, your bed is back to original, basically, no rails left in the bed. That's great if you haul lumber or dirt or whatever you might do with the bed of your truck. Finally, IMO, the B&W companion is a well made sturdy hitch, lots of US steel and heavy. The only complaint is that it takes 2 people to remove the base. But, you want something heavy attached to a 10K to 20K lb trailer...
Well you DON'T need a B&W turnover hitch to pull a GN. The puck systems will do the same thing, there are balls and hooks for safety chains for them.
The advantage of the puck system is that ALL the weight placed on the hitch is transferred directly to the frame to four points.
With the B&W much of the weight placed on the hitch is carried on the bed floor.
You can buy the factory pucks from Ram and have installed or install yourself.
BurbMan
Indianapolis, IN
rhagfo wrote: With the B&W much of the weight placed on the hitch is carried on the bed floor.
There is a structural crossmember already in place with a factory hole, all you do on the install is extend that hole through the bed floor.
From what I've seen, DIY install on the factory pucks is a lot more involved than the underbed hitch system.
BarryG20
Castle Rock, Colorado
I just recently installed the b&w under bed gooseneck hitch in my 22 ram. I am somewhat handy and had no issues it took a few hours. I need the gooseneck and the 5th wheel hitch both. Had the same in my previous truck so already had the b&w 5th hitch didn't want to have to buy a new base for the hitch to fit pucks and pay for the puck system both. Cheaper for me to just install the B&W underbed. Also putting the wiring connector in the bed was very easy. A variety of manufacturers make a harness that is plug and play. Just need to drill the hole in the side of the bed. Took me about 30 minutes to install that.
2016 Jayco 28.5 RLTS
ReneeG
Meridian, Idaho
BurbMan wrote: Lantley, good idea, I didn't think to check Hensley. The air ride is interesting, does it really improve the ride?
![[image]](https://shop.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/6/1/61858_W3.jpg)
Yes, they don't call it TrailerSaver for nothing. We have the BD3 Air ride and love it. We arrive with everything in tact and not moved in our FW.
The BD3 and BD5 come apart not requiring a hoist. It can be managed easily by one person, but a partner helps remove it faster.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Cummins12V98
on the road
"The only complaint is that it takes 2 people to remove the base."
Gee I had no idea! Guess I have been removing and installing mine wrong all these years with me, myself and I.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Cummins12V98 wrote: "The only complaint is that it takes 2 people to remove the base."
That is because you are a MANS MAN Ron ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
ford truck guy wrote: Cummins12V98 wrote: "The only complaint is that it takes 2 people to remove the base."
That is because you are a MANS MAN Ron ! ! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I guess 35 years in Construction helps.
Durb
NW
A Trailer Saver hitch will improve your tow/ride with a fifth wheel as much as your Hensley did vs. a standard hitch, Here are a couple of things to consider:
The Ram puck system sprawls over the bed, wheel well to wheel well. MY Trailer Saver is 21" wide which allows 2"x12" lumber to slide in beside it, both sides. A hitch using the puck system necessitates its removal to use the bed. I've seen some hitches where product could slide under the hitch, but it wouldn't be much.
You can remove and hang a heavy hitch using the trailer's landing gear for those times when you need a full bed. I will say it is a pain to realign and install the hitch if using standard rails. I use this method when I remove the hitch in the fall and install in the spring. I lower the hitch with a hydraulic table and roll it into the garage for winter.
I installed standard hitch rails myself using Curt model specific no drill brackets. The 45 minute job took me 6 hours. It would have gone faster if I had a lift, a helper, and better instructions. Going forward, I would have it done professionally.
Good luck with your choices.
