RV.Net Open Roads Forum: Fifth-Wheels: 5er Noob Looking for a Hitch
 > 5er Noob Looking for a Hitch
TXiceman
Full Time RVer
Posted: 01/15/22 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
spoon059 wrote:
I'm researching now for the inevitable move to a 5er. I'm planning on getting a Reese Goosebox. It allows you to swap out your traditional 5th wheel hitch on your camper with a model that is approved by Lippert to allow you to use a regular gooseneck ball in your bed. No hitch to install, move, store, get in the way... just a regular 2 5/16 hall.
It eliminates the traditional hitch in your bed and reduces or completely eliminates the chucking you get from a traditional 5th wheel hitch.
The Goose Box is a ball hitch and requires safety chains. And a Goose Box will still chuck if the road conditions are such.
Personally, my feelings are that you will be better served by a B&W Turn-Over Ball and use it with a B&W Companion hitch. You can still totally remove the hitch and not have any rails in the truck bed.
Amateur Radio Operator.
hondapro
Central Pa
Posted: 01/16/22 05:30am Link  |  Quote  |  Print  |  Notify Moderator
One issue when changing from a standard king pin hitch is you limit your options. If your truck has a break down and your 5er needs towed by someone else.
Steve
2016 F-350 6.7 Diesel
2022 Keystone Sprinter 32BH
B&W Companion
humblerb
houston
Posted: 01/16/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
Lantley, good idea, I didn't think to check Hensley. The air ride is interesting, does it really improve the ride?
Regarding removal, maybe not plywood, but drywall...you pile a few sheets of drywall on top of a hitch and it won't look like much when you get it home. Also, DW is into restoring furniture...she's excited to have a truck vs. the old Suburban because she can bring home bigger stuff now... [emoticon]
I'm thinking an engine hoist make hitch removal easy, right?
I tried the engine hoist and got rid of it quickly. Needed something I could be in the bed of the truck when lowering. Couldn't do that with the engine hoist.
I wanted to hang a winch from the ceiling. This would have been ideal and I could just "store" the hitch in the air. But I can't back in my shop far enough to clear the raised door when it is open.
Finally determined I could use a chain fall.
I have a steel shop and have a steel header above the garage door.
I installed an eye bolt and hang the chain fall from the eye.
Works great for me. Once the hitch is removed, take the fall down and store it away.
