RV.Net Open Roads Forum: Ford E450 Class C Dash Emergency Battery Switch issues
 > Ford E450 Class C Dash Emergency Battery Switch issues
enblethen
Moses Lake, WA
Posted: 01/12/22 08:06am Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD will be good helpin resolving OPs issue.
h
Here is a link to your BIRD relay including wiring diagram.
BIRD relay
IAMICHABOD can you get a photo of your wiring diagram? does it have the colors of the wiring? Looks to be same drawing as I linked.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IAMICHABOD
Sunny So Cal
Posted: 01/12/22 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD wrote:
Ya that purple wire is a puzzler,both of my purple wires that go to the BIRD,as shown in the picture have spade ends on them.
I will look tomorrow again and see if I can see a purple wire anywhere else that has a eyelet.
I remembered something last night,and went and checked today. I could not get a good picture but on mine there is a purple wire with an eyelet that goes to the small terminal on the continuous duty solenoid.
While tracing it back I found that it connected with a yellow wire then went into the fuse block.
Sorry I don't have a wiring diagram.
Former El Monte RV Rental
Buying A Rental Class C
enblethen
Moses Lake, WA
Posted: 01/12/22 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I saw a partial one on the left side of your first photo!
IAMICHABOD
Sunny So Cal
Posted: 01/12/22 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
This is what you saw.I wish it was more,but just tells what is in the box [image]
enblethen
Moses Lake, WA
Posted: 01/12/22 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
OK! Does the wiring diagram in the Intellitec manual look like your setup? They may have used different components, but wiring maybe the same.
OP: I looked at the photo that shows the splice. I doubt whether that is factory.
IAMICHABOD
Sunny So Cal
Posted: 01/12/22 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
The wiring diagram in the manual is the same as mine is wired.As for the splice I think it is factory installed,after peeling back some of the split wire loom I found the same material wrapping wire bundles and wire end connectors.
enblethen
Moses Lake, WA
Posted: 01/12/22 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hope what we gve OP helps!
