enblethen
Moses Lake, WA
IAMICHABOD will be good helpin resolving OPs issue.
h
Here is a link to your BIRD relay including wiring diagram.
BIRD relay
IAMICHABOD can you get a photo of your wiring diagram? does it have the colors of the wiring? Looks to be same drawing as I linked.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IAMICHABOD
Sunny So Cal
IAMICHABOD wrote: Ya that purple wire is a puzzler,both of my purple wires that go to the BIRD,as shown in the picture have spade ends on them.
I will look tomorrow again and see if I can see a purple wire anywhere else that has a eyelet.
I remembered something last night,and went and checked today. I could not get a good picture but on mine there is a purple wire with an eyelet that goes to the small terminal on the continuous duty solenoid.
While tracing it back I found that it connected with a yellow wire then went into the fuse block.
![[image]](https://i.imgur.com/8UXQF4al.jpg)
Sorry I don't have a wiring diagram.
Former El Monte RV Rental
Buying A Rental Class C
enblethen
Moses Lake, WA
I thought I saw a partial one on the left side of your first photo!
IAMICHABOD
Sunny So Cal
enblethen wrote: I thought I saw a partial one on the left side of your first photo!
This is what you saw.I wish it was more,but just tells what is in the box ![[image]](https://www.picgifs.com/emoticons/smileys-and-emoticons/thinking/smileys-thinking-029488.gif)
enblethen
Moses Lake, WA
OK! Does the wiring diagram in the Intellitec manual look like your setup? They may have used different components, but wiring maybe the same.
OP: I looked at the photo that shows the splice. I doubt whether that is factory.
IAMICHABOD
Sunny So Cal
enblethen wrote: OK! Does the wiring diagram in the Intellitec manual look like your setup? They may have used different components, but wiring maybe the same.
The wiring diagram in the manual is the same as mine is wired.As for the splice I think it is factory installed,after peeling back some of the split wire loom I found the same material wrapping wire bundles and wire end connectors.
enblethen
Moses Lake, WA
Hope what we gve OP helps!
IAMICHABOD
Sunny So Cal
enblethen wrote: Hope what we gve OP helps!
We may never know,OP hasn't been back for a couple of weeks.
I hate when that happens......
