RV.Net Open Roads Forum: Tech Issues: Water system going crazy help!!
 > Water system going crazy help!!
jannie4
illing
Posted: 01/13/22 07:41am Link  |  Quote  |  Print  |  Notify Moderator
water pump runs every 13 seconds abt when turn on, no obvious leaks. decided to live with. THEN decided to just hook up to the city water at the camp site. seem to do fine. but noticed later not right water pressure coming out of faucets, and toilet almost no water when flush. go out check there is water (not a whole lot but some down the place where you normally but in the water for your tank. What's going on??
ideas of what to check? thought hooking up to city water would solve problem doesn't. thanks
schlep1967
Harrisburg, PA
Posted: 01/13/22 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking the check valve at the pump has failed. When running the pump it allows the pressure to drop as water leaks back into the tank. When hooked up to city water it allows water to go into the on-board tank overfilling it.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Bumpyroad
Virginia
Posted: 01/13/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
my bounder had a small/slow leak where a valves O RING HAD A small crack and would let system depressurize by leaking water into the FW tank, and would periodically repressurize the system..
bumpy
Beverley&Ken
Tottenham,Ontario
Posted: 01/13/22 08:06am Link  |  Quote  |  Print  |  Notify Moderator
X2
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
jannie4
illing
Posted: 01/13/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
ok thanks checked outside today and when the pump is on I noticed that water coming out of the city water intake. the pump cycled before on off I had tried hooking up to city water. if ckeck value easy way not want to tear water pump apart? or is it our city water intake thing.
mfinnerty
Wentzville, Mo.
Posted: 01/13/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
city water intake thing (connection). There is a check valve on the backside of the connector. You don't say what year your rig is but my 2020 Vista had a plastic connector and leaked when I got it in 2021. Replaced it with brass fitting and been fine since.
Mike & Linda Finnerty with Finn & Rosco (Golden mix brothers)
schlep1967
Harrisburg, PA
Deleted previous entry.
Right behind the city water hook-up there should be a check valve. Replacement can be bought for around $10 at home depot.
Make sure you get all of the pieces of the check valve out before you put the new one in. On mine the retaining clip came off the piston. The piston then traveled downstream to the first joint where it go stuck, thus restricting the water flow.
* This post was edited 01/13/22 09:24am by schlep1967 *
2oldman
So Cal
Posted: 01/13/22 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Put a plug on it.
dedmiston
The West
Posted: 01/13/22 09:22am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Put a plug on it.
I always plug mine after I fill, because it sometimes runs out of that connection and starts a siphon and empties the tank.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
jannie4
illing
Posted: 01/13/22 09:36am Link  |  Quote  |  Print  |  Notify Moderator
thanks older mh 1997 shasta
