RV.Net Open Roads Forum: Fifth-Wheels: Dumb mistake
 > Dumb mistake
Page of 5
M.R.E.
MI, usa
Posted: 01/15/22 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I filled up my 5 gal can with diesei in back of pickup when towing and forgot to put cap on and drove for 3 hours in light rain. Will some water damage the fuel ? Is there something I could add to the fuel ?
toolmaker
MarkTwain
Northern, Ca. , USA
Posted: 01/15/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, through the 5 gal. can of diesel AWAY!!!!! Could cause real problems and cost you some $$$$.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 01/15/22 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
And I wouldn't worry about it. If you were driving, then the majority of the rain blew over the bed of the truck. The 10 drops that went in it will be caught by your water filter.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
byronlj
Arizona
Posted: 01/15/22 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
I bought this: https://www.etrailer.com/Automotive-Tools/FloTool/FTF3NC.html?feed=npn&msclkid=c1cc4dee00ef1daf4df92c0da443aa20&utm_source=bing&utm_medium=cpc&utm_campaign=Bing%20%7C%20Shop%20-%20Automotive%20Tools&utm_term=4577404350181664&utm_content=30%20-%2060
Works well for my WET diesel fuel.
byronlj
2013 Dynamax Trilogy 3800RL
valhalla360
No paticular place.
Posted: 01/16/22 03:21am Link  |  Quote  |  Print  |  Notify Moderator
For $15-20 worth of diesel, I wouldn't want to mess with it.
If you really feel the need, used to have a water separating funnel on the boat. If you know someone who has one, you could run it back and forth between a couple jugs (but to buy one would be more than the fuel is worth).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
MFL
Midwest
Posted: 01/16/22 04:26am Link  |  Quote  |  Print  |  Notify Moderator
For me, peace of mind, is worth much more than 20 bucks!
Just dump it properly, start over, cheap lesson learned.
Jerry
nickthehunter
Southgate, MI
Posted: 01/16/22 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Pour it into a clean 5 gallon bucket. Let it set for a day. Siphon 4-1/2 gallons of fuel off the top.
hondapro
Central Pa
Dump it for sure
Steve
2016 F-350 6.7 Diesel
2022 Keystone Sprinter 32BH
B&W Companion
KD4UPL
Swoope, VA
Posted: 01/16/22 06:41am Link  |  Quote  |  Print  |  Notify Moderator
The fuel isn't "damaged" but is is likely contaminated with water. The unknown is how much. Most diesels have fuel/water separating filters and a warning light on the dash for water in the fuel. That's all because diesel engines do not like having water in their fuel system. You could run the fuel and hope your filter catches it. It probably will. Or, if it doesn't it might damage a very expensive part(s) of your fuel system costing thousands of dollars to replace.
I don't think I'd run it.
Southern California :(
Posted: 01/16/22 07:29am Link  |  Quote  |  Print  |  Notify Moderator
If you feel lucky, use the fuel, but if you are wrong…big bucks.
Page of 5
 > Dumb mistake
