RV.Net Open Roads Forum: Fifth-Wheels: Dumb mistake
 > Dumb mistake
Page of 5
dieseltruckdriver
Black Hills of SD
Posted: 01/16/22 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Water will settle to the bottom, it will roll around on the bottom looking like mercury. Slowly pour it into another container thru cheesecloth until the water is close to coming out. Now let the new container set for a day and then pour most of it into your truck.
Slosh around the containers and then pour out and let them set upside down to drain. Done!!!
This is the best advice here. The water WILL settle to the bottom, so don't pour the entire container into the clean container. Just let the clean container sit to make sure you didn't pour too much fuel out. As someone else mentioned, use the bottom fuel to start a fire.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Cummins12V98
on the road
Posted: 01/16/22 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, water is heavier, and your description may be a doable solution, if there is no way to replace the fuel. I have to know, is this what you would do, fresh fuel readily available, or would you be more inclined to follow my advice, previously posted?
No reply needed...I already know. [emoticon]
Jerry
Since we are talking about a fuel container that most likely you can look into with a flashlight you would be able to see if the fuel has water and or debris in it. Not everyone has a creosote treated power pole at their property line as I do.
If I only saw water I would have ZERO issue doing as I said earlier. If full of crud then the power pole would get some preservative.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
SDcampowneroperator
South Dakota
Posted: 01/16/22 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
A few raindrops will settle out and be separated in your water filter. At worst case you will get a 'Water in fuel ' check light.
If you do, stop as soon as it is safe, , open the drain on the bottom of the filter and let it drain until the droplets 'sheet off' no longer 'beading off ' as droplets. A few pumps on the primer pump will help.
Use of a diesel fuel conditioner like Howes, Sea Foam or Diesel Service will dissipate water , for dissipation, not ridding the water.
Even treated dissipated water is harmful to common rail HPS diesel pumps.
Avoid the issue, deal with it, do not try to 'treat'' it away.
TXiceman
Full Time RVer
Posted: 01/16/22 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
mhardin wrote:
I would never knowingly put contaminated fuel into a truck with a $10,000 engine. If water makes it to the injector pump and it eventually grenades you will be looking at a huge repair bill.
Better check the price for those diesel engines. Had a new crate 6.7L engine put in the truck in October 2014. Back then the engine was almost $16,000 and the installation at the Ford dealer was $23,800. Fellow here in the park had his 2015, 6.7L Ford take a dump. A remanufactured engine installed is $15,000.
No way would I take a chance on that contaminated fuel unless it was run through a proper oil/water separator.
Ken
Amateur Radio Operator.
Lantley
Ellicott City, Maryland
Posted: 01/16/22 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like a lot to go through for $20.00
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
SDcampowneroperator
South Dakota
Posted: 01/16/22 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly my point. Treating away the water is more costly than dumping suspect fuel.
That raises another issue, how and where to dump contaminated fuel?
Theres the kicker, do you trust the water separator filter and do you know how to service it? If not, read you tube for a minute about your truck.
valhalla360
No paticular place.
Posted: 01/17/22 12:16am Link  |  Quote  |  Print  |  Notify Moderator
Use it for starting fires as someone mentioned.
Or offer it to someone for free (be honest about what happened)...there seem to be plenty of folks willing to much about with their 5 figure engine to get $20 in diesel fuel based on some of the posts.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
Indepmo
Posted: 01/17/22 04:17am Link  |  Quote  |  Print  |  Notify Moderator
Back in the day I would let truck set overnight, then drain about 5 gallons of fuel out of each tank every fall to be sure no ice in winter.
I would use that fuel for parts cleaner, add to the oil I turned in for recycling.
MFL
Midwest
Posted: 01/17/22 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Three pages of response, but OP has not returned. With the mixture of solutions, I wonder what the OP plans to do? I am guessing he hates to waste the small amount of fuel, or he would not be asking. Is it safe to use, worth trying to separate, worth the stinky mess on your clothes, hands, and shoes? I think OP was asking, should I just dump it in the truck, or not?
Let us know OP, is it worth the risk to YOU?
Jerry
M.R.E.
MI, usa
Posted: 01/17/22 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses. Not worth the risk, but where do you dispose ?
toolmaker
Page of 5
 > Dumb mistake
