fj12ryder
Platte City, MO
I take it this Jensen TV doesn't have separate inputs for DVD, Cable, HDMI, or RCA cables. That would seem to be the only reason to have a modulator on it. Or am I looking at this incorrectly?
Howard and Peggy
"Don't Panic"
greg121
TX
Thanks for all the interest. Yes, modulator is built into the switching box and I've tried TV (which is what I kinda recall using when it last worked, if I watched more often than once a month or so I might be more certain of settings). Anyway, tried several - TV, AV, DVD changing input source as appropriate.
Jenson has all above inputs plus 2 HDMI. Why in this day and age Winnebago set it up for modulator is beyond me but was OK with til it didn't work
All cabling in the wall or behind the Entertainment panel where player and switching box are. Looking like I'll have to open it up and see what's connected to what.
1995brave
San Antonio, TX
You also might want to start playing a movie before you rescan for channels.
Tom_M
New Hope, MN
Since doing a scan picks up TV stations it sounds like the antenna is still connected to the TV. Your switch box should have a DVD player button. If all else fails, connect a coax directly from the F connector on the DVD player to the antenna in on the TV and do another scan.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
