rpa7611375
Canada
I have a 2005 Fleetwood PaceArrow 36B. I have water that drips from in front of the rear duals on the passenger side of the coach. I have checked and I am fairly sure it is not coming from the slide. Has anyone ever had this happen to them and what was the cause and the fix. Thanks for your help.
rk911
DuPage County
either a leak in the fresh water piping or from your gray or black tank. dab a drop or two on your finger and do a sniff test. betcha it's from the fresh system.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
2112
That's right where the shower is. Is it a constant drip all day long?
2013 KZ Durango 2857
jdc1
Rescue, Ca
Could be mice, squirrels, rats......chewing through the PEX piping. Gotta pull off the underbelly covering and start tracing it down. Might even have to pull off interior paneling, if the valve-set is accessible that way...
MountainAir05
New Mexico
Is the pump running more. Turn it off and wait. Also it could be grey water.
rpa7611375
Canada
Hey everyone. Getting back to my water leak I have now removed the shower, the vinyl flooring and the washer dryer that is located in the kitchen slide. I could not find a leak anywhere that was obvious. No water damage in the slide or under the shower. The plywood in the middle of the floor between the fridge and slide was completely saturated through. I removed the wet plywood and only found styrofoam insulation. As there are no water lines of ant sort in this area does any one have any ideas where the water would be migrating from?
Where is the water heater? Mine sprung about a hundred pinhole drips,.
rpa7611375
Canada
It is under the vanity sick which is just beside the shower.
ScottG
Bothell Wa.
Any chance there are low point drains there?
rpa7611375
Canada
Yes both low point drains are by the water heater
