RV.Net Open Roads Forum: Fifth-Wheels: Equa-flex suspension?
 > Equa-flex suspension?
freewayrandy
'Old Hangtown', Ca
Posted: 01/19/22 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I'm having the hardest time getting grease to go in. Any tips how to grease those fittings? Shackles take grease ok.
2015 Chevy 2500HD Duramax/Allison, 2018 Grand Design Momentum 328, 2005 Polaris Sportsman 500, 2018 Polaris RZR 900
jjj
Lancaster,Ca.U.S.A.
Posted: 01/19/22 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe a bad zert fitting. Might try replacing the zert with a new one. I had
To do that to one of mine.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
buc1980
houston tx
Posted: 01/19/22 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Take the pressure from the wheels pick up some from the ground.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.
southernsky
Ponchatoula La.
Posted: 01/20/22 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Jack it up from the frame and stretch your suspension
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
ACZL
UPstate,NY
Posted: 01/20/22 08:51am Link  |  Quote  |  Print  |  Notify Moderator
X3 on raising the susp off the ground.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
C Schomer
Pueblo West, Co.
Posted: 01/25/22 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve had some of the wet bolts that weren’t drilled all the way through and there was no way to get grease into them. Craig
RCMAN46
NorthWest
Posted: 01/26/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
If you have never had the Equa-flex take grease Schomer is on the right track. When I installed my wet bolts I also had several that were not drilled all the way through.
ScottG
Bothell Wa.
Posted: 01/26/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Same here, didn't realize it until the next year when I went to grease them. eTrailer told me "Sorry".
Haven't bought anything from them since.
C Schomer
Pueblo West, Co.
Posted: 01/27/22 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, it was about 2012 that I got those bad bolts and it was when I bought Dexter easy flex and wet bolt/shackle kits from E trailer. Several guys posted that they had the same problem. I wonder how many more of those bad bolts they have! Craig
laknox
Arizona
Posted: 01/28/22 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Easy enough to check. Drop a small drill bit down each hole and, if you can't see it, then send the whole thing back...under warranty, on their dime. You'd think it was an LCI product...
Lyle
* This post was edited 01/28/22 04:45pm by an administrator/moderator *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
