RV.Net Open Roads Forum: Truck Campers: Wind Deflector
 > Wind Deflector
ticki2
NH
Posted: 01/23/22 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Sleepy’s airfoil project is the TCU under camper exterior
'68 Avion C-11
'02 GMC DRW D/A flatbed
billyg
iron station nc
Posted: 01/23/22 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hi it's been a while since I responded to something here is my 2 cents. I actually installed an inverted bug deflector made by stampede that goes on a 1999 chevy suburban. It works great for me. Bill
Hemi Joel
Minnesota
Posted: 02/02/22 12:46am Link  |  Quote  |  Print  |  Notify Moderator
I was on a road trip and picked up a hood for one of my project cars. I had no place to haul it except strapped to the roof of the truck. I was surprised to find that it picked up almost 1 mpg on the 900 miles home. I'm going to build a deflector, probably like Sleepy did.
2018 Eagle Cap 1163 triple slide, 400W solar, MPPT, on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
bighatnohorse
Gig Harbor - Cave Creek
Posted: 02/02/22 07:33am Link  |  Quote  |  Print  |  Notify Moderator
On a 1000+ mile trip I picked up 1.5 mpg simply because of a slight tail wind.
It only take a mild 5 mph wind (head or tail) to make a difference.
HMS Beagle
Napa, California
Posted: 02/02/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I'm about half way through the build on mine. I bought a bumper valance (replacement for stock) for a 4wd truck same year and model (2015 F350). The 2wd version is 4" tall, the 4wd version is 7" tall. Decided to make a fiberglass plate with blind nuts to mount it, that way it is easily removable/replaceable for maintenance or testing. This will be stuck to the camper overhang with VHB or PU (no holes). The styling dept. at Ford made the valance match the width and approximate curvature of the truck cab so it doesn't look too bad. It is plastic so incidental contact with the cab will not be catastrophic. It was cheap and seems durable. Only question now is how far forward/back to mount it. It would be great to be able to experiment with that but I've got no ideas how to hold it in place temporarily to try.
I'll post some pictures when I get it done.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Bedlam
PNW
Posted: 02/02/22 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I always get better mileage going east than west due to the trade winds. It hasn't been enough difference to circumnavigate only in one direction.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
mountainkowboy
Socal/NE Oregon
Posted: 02/02/22 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
It had to be 15 years ago when we went through the same motions. There were many designs that were tried, and this is what we found.
The "air foils" did nothing for fuel mileage. Some improved aerodynamics and had less buffeting. Most kept the underside of the bed cleaner of bug guts. I tried a "V" design similar to the one in the pic. It did keep the under cab bend much cleaner of road grime, but increased buffeting on our supercab with the windows down. So it was removed.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
MikeJinCO
Salida, CO
Posted: 02/10/22 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Beagle- look at the 3M double sided tape used to hold solar panels on available at the hardware in several strengths. Have mine done, just need to get to warmer weather to put it on as camper has to come off. If it quiets down the buffeting I'll call it a great success.
HMS Beagle
Napa, California
Posted: 02/10/22 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I've got the valence, built and painted the mount, and have the 3M VHB to attach it. All that remains is sticking it to the camper. That requires at least two on/off cycles which I will get to in the next couple of weeks.
There is some question as to where the ideal position would be. It would be nice to be able to trial it at several positions before mounting permanently. I'm guessing about even with the top of the window glass or slightly behind that.
MORSNOW
Mountain Home, ID
Posted: 02/11/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Sweet! Looking forward to hearing about your results, both good and bad.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
 > Wind Deflector
