RV.Net Open Roads Forum: Tech Issues: Icemaker quit --- any ideas ?
 > Icemaker quit --- any ideas ?
JoeH
Apollo Beach,FL
Posted: 01/22/22 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Ice maker on our Maytag French door refer ( model MFI2269VEM10) just quit... was working good for the past couple months we've been traveling. Water dispenser in door works fine. Switch is on, arm is down.... guessing there is a solenoid or relay somewhere that's not working. Any experience in troubleshooting this ? Maytag website is not very useful, just high level suggestions. Thanks !
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Ranger Smith
Wherever the rig is parked
Posted: 01/22/22 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Icemaker probably went bad. Solenoid is usually at back of fridge where water connects. You can get a replacement icemaker on Amazon for usually around $40.
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
bgum
South Louisiana
Posted: 01/22/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Time to replace.
Dave H M
IL
Posted: 01/22/22 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, throw a new one at it and go from there.
Posted: 01/23/22 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Check the solenoid. check the tube from there to inside.
Rip the thing out and get a countertop ice maker machine (what I did) take advantage of the added freezer space and longer time between Defrost on the Fridge.
Posted: 01/23/22 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Could just be froze up, literally.
But yeah “rip it out”, lol.
PS that was a joke. Maybe a solution for some, but a working ice maker IN your freezer sounds preferable to another encumbrance on the counter.
2017 Heartland Torque T29
mobeewan
Hampton, Va
Posted: 01/23/22 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
I took mine out of the one at home to get more freezer space. For ice I freeze water in either a Ziploc bag or glad of Ziploc food storage container and break it up or use small cube or water bottle ice trays.
Posted: 01/23/22 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have had the water supply line (The fill line) freeze yes.
In my RV however said line split.. Well I had no clue as to how hard it would be to replace so I "Ripped" the ice maker out (Well removed it carefully in case I ever wanted to replace it) I got a lot more space in the freezer (nice) and thanks to a countertop ice maker a lot more ice as well
Plus the ice maker is a major source of moisture in the freezer compartment so defrosting was reduced. A win-win-win when I pulled it.
JoeH
Apollo Beach,FL
Posted: 01/25/22 05:57am Link  |  Quote  |  Print  |  Notify Moderator
The ice maker in the French Door refer is in the refrigerator compartment, not the freezer. Anyway, I found a PD guide and the icemaker is toast.... will order a new one when we get home
Dave H M
IL
Posted: 01/25/22 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Joe, on second thought I have a Samsung in the stick house that has french doors and the ice dispenser in the frig compartment. It has quit three times. Problem has always been a freeze up. I got the fix down to a science now. Pull the cube drawer/catcher and use the DW hair drier on the innerds until all ice in the mechanism is thawed. Turn the power back on and it is good to go for a year or so. [emoticon]
