mymirada
nc
Fuel pump I'm looking for is 149ā2267 there seems to be other models that are anywhere from $50-$80 each for some reason the cheapest price I could find for mine is $225 does anyone know of a replacement or a universal model that can be used it's a 1998 coachman Mirada that has an onan /cummins generator
Appears Cummins themselves wants $333 for that one!
Personally Iād drop in something meant for carburetors that costs about $50 and take my chances with it before paying that much for a cheap little fuel pump.
Fwiw, there is no reason for that part to be that expensive. You could buy 3 Holley 100+ Gph fuel pumps and a regulator for that much.
2016 Ram 2500, MotorOps.ca EFIlive tuned, 5ā turbo back, 6" lift on 37s
2017 Heartland Torque T29
Gjac
Milford, CT
Just match the psi rating, head rating and flow rate rating from your exiting pump. When mine failed on a trip I replaced mine on the road from an auto parts store for about $25.
I-Can-Am-Can-You
Licking County, OH
I used an auto parts store low pressure pump and I keep a spare with me just in case.
Currently about 500 hours on that cheap replacement.
Skibane
San Antonio, TX
That looks like an ordinary, garden-variety Carter electric fuel pump.
This website shows the specs - none of which are unusual:
https://www.rvupgradestore.com/Onan-149-........Diesel-Generator-Fuel-Pump-p/90-7852.htm
garyemunson
Reno, Nevada
https://www.jegs.com/i/Carter/180/P4594/10002/-1?gclid=Cj0KCQiA_8OPBhDtARIsAKQu0gaiEYH-o2_VQN3LfdBDDfZtfSVcHNUwZGRrnMovef2f3zVxOBME6uAaApicEALw_wcB
