RV.Net Open Roads Forum: Best solutions for internet - REAL solutions please!:)
 > Best solutions for internet - REAL solutions please! :)
Posted: 01/30/22 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Ranger Smith wrote:
We use the FMCA hot spot at 49.95 a month. Can stream 3 TV's and internet with no issues or throttling. We have been all over the East Coast, Texas and out west. It has worked everywhere so far.
I used that my last year in the RV. Very happy with it.
NOTE unlike every other cellular program that I've had
Including ones called "Unlimited" (Unlimited data but limited high speed.. Not the same as UNLIMITED)
The high speed data limit on the FMCA plan... 8 (That is the symbol for Infinity in case you do not know it)
RedRollingRoadblock
Oregon
Posted: 01/30/22 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Seems as though the ultra-modern software here turns it into an eight.
Second Chance
Wherever...
Posted: 01/30/22 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
These folks are the gurus on this topic - lots of good information:
RVMobileInternet
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Thermoguy
Graham, WA
Posted: 01/30/22 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Is FMCA just a Sprint mobile internet plan? How does it work if you have a poor cell signal or no cell signal? Seems like it would be the same as any cell service - is this incorrect?
I have a Verizon jet pack and when I get to about 1-2 bars, it is worthless. Won't load anything on my devices.
Starlink will be the solution, but it's still a couple years off. Not sure how the cost of expensive hardware and $100 a month will make it worth it.
Sometimes it's nice to just check out of technology.
Gdetrailer
PA
Posted: 01/30/22 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
FMCA is nothing more than a reseller of Sprint.
There are only three real cellphone OEMs, Verizon, ATT and Sprint. Every one else is nothing more the resellers, buying services from one of the big three.
It is possible to have one or more of the big three OEMs close enough to you to work for any of the big three OEMs or only one close OEM enough to work but you are not on that specific OEM network and you have no signal.
Not all three OEMs have good coverage in all areas and you need to do your homework to figure out which of the big three OEMs have a tower closest to where you are planning to camp.. Unless of course you subscribe to multiple OEMs services..
In my area home, ATT has more towers (three within 3 miles) close to me, Verizon has one (two miles from me) and Sprint has zero (IE zero service, Sprint in fact has only one tower in my entire county which happens to be near a Interstate far, far from me)..
Sprint and Verizon tend to have more towers near larger Metro areas, ATT seems to have a bit more coverage in rural areas like I am in.
With 5G rollout and 3G networks going dark soon, everyone will be relying on 4G LTE networks even heavier changing the coverage landscape. 5G does not go as far and requires more towers making it a lot more costlier to roll out to rural areas so your are most likely only going to see true 5G close to big metro areas.
There are cell tower maps you can search the internet for which can show the concentration of cell towers for each OEM carrier and the coverage of those towers instead of guessing.
theoldwizard1
SE MI
Posted: 01/30/22 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Sprint was bought out by T-Mobile. If you have a cell phone or hot spot that runs on Sprint you will soon need a new SIM card.
jorbill2or
Full time
Posted: 01/30/22 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
Yes there are 3 but not Sprint it’s T-Mobile. Sprint is gone Sprint plans are really T-Mobile and as noted will need new phones or hotspots to fully take advantage of tmobile. Sprint devices are using the old sprint that’s still left and what T-Mobile that they can receive.
As I said If you travel a lot to most of the country you need at least 2 of the three. There are places with no cell service yes but they are fewer and fewer.
* This post was edited 01/30/22 04:52pm by jorbill2or *
Bill
TechWriter
Part-Timing Again
Posted: 01/30/22 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
crasster wrote:
I'm having a lot of trouble traveling because I can't get a "decent" connection. I must have one for part time work.
Decent means 10mbps . . .
3) How is starlink?
Very good for a stationary location. I've had it for about a year and DL speeds are almost always 100+ Mbps. Starlink has become very stable over time.
However, for mobile use, I don't think it's there yet. Starlink service is not guaranteed in all areas.
crasster wrote:
4) How is any other satellite internet?
I used a portable HughesNet Gen 5 dish for two years and it was bullet proof. DL speeds averaged to 10+ Mbps. And service was available as long as you could see the Echostar 19 sat.
However, HughesNet Gen 5 is expensive and klunky. The equipment you need for a portable system (dish, tripod, modem, etc) costs about $1500. Then you must purchase a data plan (which you can change every month in you want) which range from 2 GB/mon ($40) to 1 TB/mon ($2000). We opted for the 50 GB/mon data plan for $120/mon.
FYI -- this is Business HughesNet Gen 5, not Residential. In short, it means you use a bigger sat dish and have more data plan choices AND you can move it around.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
Dutch_12078
Winters south, summers north
Posted: 01/30/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
crasster wrote:
Dutch_12078 wrote:
As Jon said, a MIMO (Multiple In Multiple Out) antenna set is a good choice if your hotspot or router supports it. I use an aimable dual Yagi set that has equaled or out performed our previous $600 amplifier/repeater everywhere we've been with it at less than one-third the cost. My set is mounted just above our Winegard "batwing" TV antenna.
Thank you!
What type of router are you using?
I use it with either a Verizon or AT&T hotspot depending on which signal need the most help.
Dutch
2001 GBM Landau 34' Class A
Dutch_12078
Posted: 01/30/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Gulfcoast wrote:
Hey Dutch.... could you please post a picture of the rear of your batwing antenna? I have my yagi's, just need to see the best way to build a bracket for them. I have to build a bracket that will allow the antenna to go up and down, but I haven't worked that out yet. Thanks
Here's a couple of shots of the back and the roughed out bracket. The red arrows on the antennas were just temporary to indicate the top so a condensation vent was at the bottom. The bracket was cut from a piece of 1/4" thick scrap aluminum. The two larger holes were already in the scrap piece, and were not used. The antenna mounts themselves are just the 'L' brackets that came with the antennas hammered flat. The antennas maintain the same orientation when lowered the same as the batwing.
