Bionic Man
Colorado
I70 is in my back yard. I think it’s kind of comical the apologists for the Rivian here. I see no way to have a position that this truck is ready for prime time towing duties. It simply isn’t.
Hard pass from me on this technology for the foreseeable future.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
BCSnob
Middletown, MD
All I’m suggesting is there are ICE tow vehicles being used around the country now that would also fail that test and yet no one is suggesting we should give up on all ICE tow vehicles or not even try to improve their capabilities.
Btw how did the f150 ecoboost do with this test? What would the range be for 3.5mpg with a 26gal tank?
ksss
Eastern Idaho
BCSnob wrote: All I’m suggesting is there are ICE tow vehicles being used around the country now that would also fail that test and yet no one is suggesting we should give up on all ICE tow vehicles or not even try to improve their capabilities.
The difference is when you get to the top with the F150 you fill up and 10 min later you move on with your life.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
BCSnob
Middletown, MD
World's fastest EV charging station promises a full battery in under 15 minutes
Link
ABB will open the first station in Europe by the end of this year. Next year, it will expand to the US and around the world.
Btw, there are no stations (fuel or charging) at the top, you have to get through the tunnel and down the other side to silverthorne to fill up or turn around and go back down to Georgetown.
Never mind, company is building 360kw stations, there’s already a 350kw station in Frisco which takes 40min to charge a Rivian. Charge times are the current issue for cross country trips in EVs. Range towing may already be comparable to a f150 ecoboost.
There is this work from Purdue U engineers
Cooled charging cable
last
edited 02/01/22 09:39pm by BCSnob *
View edit history
1320Fastback
Vista, Ca
and I guess I'll keep my 30 year old Dodge a while longer. There something about having a 300+ mile range that's makes getting somewhere before sunset possible.
It looks like their truck overheated the battery/motor/? systems and did not recharge on the way down the hill much at all. Also why would they not put the trailer brakes on 1 or 0 so the truck does most if not all the slowing? Sure it wouldn't be safe but it would bump up the regen numbers not having the trailer brake it's self and you know dang well people will be doing that when they figure out the range problem and actually start towing with electric trucks.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
BCSnob
Middletown, MD
I’d like to see head to head f150 ecoboost vs Rivian tow 7-8k from golden to vail and back and then compare total time and fuel costs. My guess is Rivian will cost less while f150 will take less time due to much shorter refuel times. I don’t know if the f150 will keep pace towing uphill.
I doubt the folks at Rivian design their product to compete in the full time TV market; it seems more designed to compete in the daily drive occasional TV market (a much larger market than full time TV). The comparison above is more in line with what the Rivian will compete against.
edited 02/02/22 05:19am by BCSnob *
Reisender
NA
The only thing that kinda surprises me is the 160 kw charge rate at a DCFC. I’m not sure why they did that. I’m not an expert but even on this truck with the smaller 135 kWh battery they should be able to handle 250 kw or more. Even a little 82 kWh battery in our Tesla peaks out at 250 kw.
Maybe their 180 kWh battery will charge faster. That’s probably 6 months away. I wouldn’t be surprised if they redo this test with the big battery though.
Adam R
ut
So, the truck goes from 100% to 15% of charge and then up to 52% of charge at a cost of $17.36 in Dillon. It then goes back down to 16% on the return trip to Denver. Let's assume it can get back up to 100% of charge for $34 on the second charge so the cost from Denver to Dillon and back is $51 in round numbers. The round trip mileage is 140 miles. So the cost of electricity is roughly $0.36 per mile. My 2019 Ford diesel could pull that same route and easily average 10mpg round trip so I would burn 14 gallons of diesel for that same trip. At $3.50 per gallon, my fuel cost would be $49 or $0.35 per mile. While not against an electric vehicle, the justification is far from being a slam dunk at this time. Plus, I could pull twice that weight, have 5 times the range when empty and fill ups take 5 minutes. I'll keep my Ford for now. Adam
Reisender
NA
Adam R wrote: So, the truck goes from 100% to 15% of charge and then up to 52% of charge at a cost of $17.36 in Dillon. It then goes back down to 16% on the return trip to Denver. Let's assume it can get back up to 100% of charge for $34 on the second charge so the cost from Denver to Dillon and back is $51 in round numbers. The round trip mileage is 140 miles. So the cost of electricity is roughly $0.36 per mile. My 2019 Ford diesel could pull that same route and easily average 10mpg round trip so I would burn 14 gallons of diesel for that same trip. At $3.50 per gallon, my fuel cost would be $49 or $0.35 per mile. While not against an electric vehicle, the justification is far from being a slam dunk at this time. Plus, I could pull twice that weight, have 5 times the range when empty and fill ups take 5 minutes. I'll keep my Ford for now. Adam
Fair enough. But it’s a half ton. And it doesn’t have the optional bigger battery. I’m not sure they meant this to compete with heavy duty diesel pickups. Heavy duty diesel pickups do what they do very well. But in turn, for a sport truck buyer those diesel pickups wouldn’t hold a candle to something like a Rivian in terms of sport truck performance. Right tool for the right job etc.
Jmho.
Adam R
ut
I keep hearing that EV's cost so much less to operate in energy costs. In this test, the cost to drive 140 miles in the Rockies is essentially a wash. Empty, I'd get closer to 17 mpg in that same trip. Yes, it can get to 60mph about 5 seconds faster than my F-350. That would effectively account for 0.00001% of my average driving experience and with 450hp on tap in my stock truck it is no slouch. Even using an F-150 Ecoboost, it would still be a wash and the R1 is smaller than an F-150. So what are the benefits of this truck? Cost more to fuel, smaller, less capable, gives you anxiety, costs you time while on the road to refuel, but hey, it saves you 5 seconds from 0 to 60. Oh, and it has no soul either. Now if I was just a commuter living in the city, it might be worth considering, but out west, with lost of distance between A and B, it's not practical at this time.
