Cliff_Michele
Seattle, WA
Dont have a TC yet but what about cutting top sheets and blankets down the middle? When you go to bed you slide in your side and pull your covers over you. No need to wiggle to the top of the bed and then back down. TC on the way but that is our thought.
"If you think you can when you can't, you just might!"
No RV yet but getting closer! We are too old for this tent stuff!
Cliff and Michele (Humans)
Toby and Bailey (Bichons)
WarrenS65
SoCal
When it's just me, I use a sleeping bag. My wife insists on sheets. I say ok, but you put them on.
2022 F450
2022 Host Everest
2021 Yamaha YXZ1000R
1987 Honda TRX250R
2002 Honda 400EX
1998 Yamaha Warrior
2006 Yamaha Raptor 250
2018 Look 24' enclosed trailer
egarant
Mission Viejo CA
After using almost all the previously mentioned configurations of bedding we are now trying out Beddy’s Bedding. Kinda like a sleeping bag but much more confortable and nice looking. Very easy to make the bed. I recommend upgrading to the higher quality sheets inside.
Beddys
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
Deb and Ed M
SW MI & Space Coast, FL USA
MY TC is a popup, so it's not too hard to pull the queen-sized mattress down to where I can stand on the floor, slip the fitted sheet over the top, then push it back up and finish putting the sheet over the bottom. Then - Ed and I have our own twin-sized sheets/blankets because we never agree on how much we need (plus he steals the blankets). The twin size makes washing bedding easier. If it's going to be truly cold, we always carry a couple of lightweight sleeping bags to use unzipped like comforters
ppine
Northern Nevada
Sleeping bags and blankets.
It is what I use at home.
I often use a top sheet but not folded in, loose under the blanket.
deltabravo
Spokane, WA
Lwiddis wrote: Large, washable, inexpensive sleeping bags are one idea.
Ditto!
davidreyan15
New York City
Or I can tell you what they told me when I asked:
Suck it up buttercup. (paraphrased)
Making the bed in my TC is a spelunking expedition. I have to crawl UNDER the mattress to get the sheets and blankets tucked under the far side.
I wrangle the fitted sheet on while on the bed, then throw the flat sheet and blanket over the far side, then crawl under the mattress and pull it under.
edited 04/13/22 04:25am by davidreyan15 *
Hydro-Lazer
JimK-NY
NY
davidreyan15 wrote: Or I can tell you what they told me when I asked:
Unfortunately I have done the same for years....and I hate it. My mattress is 8" of fairly dense and definitely heavy foam. Trying to get under, raise the mattress and wrangle the fitted sheet in place is a major chore. There must be a better way.
rickjo
SW New Mexico
Cliff_Michele wrote: Dont have a TC yet but what about cutting top sheets and blankets down the middle? When you go to bed you slide in your side and pull your covers over you. No need to wiggle to the top of the bed and then back down. TC on the way but that is our thought.
Don't know about the cutting. We have a king size memory foam mattress in our cabover. Fitted pad and sheet isn't too bad to put on. Then we each have our own top sheet, blanket(s) and spread sort of tucked in on one edge. Getting in and out in the middle is a breeze and with the memory foam, we can often accomplish that without waking the other up. Worked for 15 years so far.
Rick
2019 F-350 4WD Crew Cab DRW 6.2 l gas engine (6500 lbs cargo capacity!)
2007 LanceMax 1181 loaded, King memory foam mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
