RV.Net Open Roads Forum: Black Tank Valve/Discharge Under Coach Rather Than In A Bay?
 > Black Tank Valve/Discharge Under Coach Rather Than In A Bay?
Jedidad
Cocoa Beach
Posted: 02/01/22 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
bukhrn wrote:
Every Class C I've seen (including mine) have this arrangement, the only RV's I've seen with the dump in a Bay, are Class A's...
Ah, you're right. I've been primarily looking at Class A's recently.
Lumpty
Greater Gotham City
Posted: 02/01/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
As a FYI, Forest River Sunseeker and Forester Class C's built since the 2010 or so timeframe have compartment-enclosed dump valves. My '11 also has a removable screw cap in the floor of the nyloplast compartment floor to run a stinky slinky through for full hook-up connection routing. The black and gray tanks themselves are located above the chassis frame and the bedroom/bathroom floor(s), in the mid to rear section of the house in a step-up area inside.
So, there are at least a few C's out there
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
wildtoad
Blythewood, SC
Posted: 02/01/22 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Having the dump tube and valve underneath is a common setup. All of my previous units had the tube/valves underneath. My current mh has the tube and valves contained inside protected from the elements possible damage. HOWEVER terminating a sewer pipe inside a mh brings with it it’s own set of problems should something go wrong, and can make replacing a failing valve a real chore.
More than one person has been welcomed by a rush of poo from a leaky (or insufficiently closed) valve when removing the end cap.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Dutch_12078
Winters south, summers north
Posted: 02/01/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
In many years of working on RV's of various configurations, the only undercarriage dump valve setups I've repaired other than the typical location independent leaking valves were ones where the owner backed over a high curb or rock, etc.
Dutch
2001 GBM Landau 34' Class A
EMD360
Arvada, CO
Posted: 02/01/22 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
I worried about the exposed tank valves on our new Minnie Winnie. Our Itasca valve was inside a compartment and I could keep the hose and connections in there too. Very convenient. But it appears this feature has morphed from Winnie’s to Foresters. One benefit of the exposed valve is that more types fittings are possible at the valve. The Itasca had a sharp angle from the opening to the valve and the tube we had was flexible enough to make the connection but I tried a newer tube and it didn’t work.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
lancewgurel
Spokane Valley WA
Posted: 02/02/22 03:19am Link  |  Quote  |  Print  |  Notify Moderator
My 26' 2000 Jamboree is inside a 'basement' compartment. My questions is: how do the exterior tank dumps work in freezing weather. We travel in ours in the winter, and we run a 60 watt droplight in there when the outside temps fall below 25.
bobndot
Posted: 02/02/22 03:48am Link  |  Quote  |  Print  |  Notify Moderator
My 2018 F. River Sunseeker class C has its dump valve inside its own compartment .
