RV.Net Open Roads Forum: Jeep GC diagnostic plug and AF one braking issue
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Jeep GC diagnostic plug and AF one braking issue
Land Yachters
Philadelphia
Posted: 02/02/22 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Hard to say what I needed in subject line. Have had 2018 Grand Cherokee towed behind my Tiffin for over a year and about 18,000 miles. No problems with Blue Ox hardware and Air Force one braking. One of the service lights came on in car (service stability control), made appointment at dealer, and he said he couldn't hook up diagnostic cable to see what the issue was because it was blocked by the brake hardware installed on pedal. He said that would be an issue on any service required and not having diagnostic readings to go on. I left and will call shop that installed the system, but was wondering if anyone has had this issue. I think the Jeep/GC and Air force One combination is pretty popular out there.
Thanks for any guidance.
Land Yachters
Griff, Ali and Coco
Philadelphia, PA
2018 Tiffin 33AA
2018 Grand Cherokee
sch911
Rochester Hills, MI
Posted: 02/02/22 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
They just installed it in a bad place, most likely over top of the diagnostic connector in the JGC. That connector is under the dash to the left of the steering column.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
CA Traveler
The Western States
Posted: 02/02/22 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a bad install. Perhaps install on the other side of the brake pedal or see if there is other hardware to solve the issue. I'd want a much more experienced person to correct and check the entire system for potential problems.
As a last resore take pictures, mark the cylinder location with tape and then remove it for your service.
2014 Grand Cherokee Overland
Bob
